Amanda McDermott Posted April 26, 2023 Share Posted April 26, 2023 Hello, I think @Katarina Ollikainen mentioned this the other day as something you can do using 'b' tool, but it isn't working for me... I have background landscape areas, overlaid by bulb planting areas, and want to tag both. Even when I direct the end of the data tag line to a part of the landscape area not covered by the bulb area, it is only picking up the bulb area in the foreground, even using the 'b' key. I have found a workaround by exiting the annotation, switching off the bulb layer, tagging the landscape areas, then going back out, switching on the bulb layer, going back into annotate the bulb layer. But this is cumbersome and also if I then want to move tags they flip back to the bulb data! Hope somebody can advise... e.g. should look like Quote Link to comment
Tom W. Posted April 26, 2023 Share Posted April 26, 2023 This is a perennial problem (sorry!) with Data Tags across the board. I sometimes have objects I simply have no way of tagging where I want them tagged: when I pull the marker to where it needs to go I lose the association. I have to resort to ungrouping the tag in order to have it display correctly in the location I want it. Quote Link to comment
Vectorworks, Inc Employee Katarina Ollikainen Posted April 26, 2023 Vectorworks, Inc Employee Share Posted April 26, 2023 Hi @Amanda McDermott, I would suggest to first tag everything you can reach. If there are things you for some reason can't get to even with the B-key, go up to the toolbar and switch to the third mode - when you then hover over the design area, everything not tagged will go red and you can click once and get all of them tagged in one go. After that it's easy to adjust the tag to where you want it. This is also very useful when tagging planting plans and you want to ensure you haven't missed a plant group somewhere. Let me know how you're getting on 1 Quote Link to comment
Tom W. Posted April 27, 2023 Share Posted April 27, 2023 15 hours ago, Katarina Ollikainen said: After that it's easy to adjust the tag to where you want it. Is it though? I have had instances like I describe where I can't move the tag where I want it without it losing its association with the object. And @Amanda McDermott I think says the same. I had to ungroup the tag in order to position it where it needed to be (right next to the object I should hasten to say!) + still display the correct info. Quote Link to comment
Amanda McDermott Posted April 27, 2023 Author Share Posted April 27, 2023 Thanks both, Katarina's way is a very useful tip - and I can move the text side of the tag once created, but if I move the end point of the line from where it's automatically been put, it flips to the other data. So, not ideal but better than what I was doing... if I'm really unhappy with where the line is pointing I guess I'll have to fall back on my workaround. One for the wish list to sort out properly please! I'll post on the wish list thread. 1 Quote Link to comment
Christiaan Posted April 27, 2023 Share Posted April 27, 2023 This is the workaround I've been offered too. You can see it in action here for some windows I couldn't tag. All eligible objects mode.mp4 2 Quote Link to comment
Tom W. Posted April 27, 2023 Share Posted April 27, 2023 32 minutes ago, Amanda McDermott said: but if I move the end point of the line from where it's automatically been put, it flips to the other data. exactly 1 Quote Link to comment
Amanda McDermott Posted April 27, 2023 Author Share Posted April 27, 2023 (edited) @Tom W. @Christiaan do go and upvote my wish list item, if it's not you who already has! Edited April 27, 2023 by Amanda McDermott 1 Quote Link to comment
Amanda McDermott Posted April 27, 2023 Author Share Posted April 27, 2023 p.s. @Katarina Ollikainen/all, I've got an extra row appearing at the bottom of my plant schedule that just says quantity 0, and has no other data - how do I get rid of that?! Quote Link to comment
ElizabethB Posted April 27, 2023 Share Posted April 27, 2023 I've had this problem too. So frustrating. 1 Quote Link to comment
Peter W Flint Posted April 27, 2023 Share Posted April 27, 2023 7 hours ago, Amanda McDermott said: how do I get rid of that?! Can you delete the row when you r-click and edit the table? Quote Link to comment
Pat Stanford Posted April 27, 2023 Share Posted April 27, 2023 Try and right click on the row header (3.xx) and choose Select Object. That should select the object and change layer and class visibility so you can see what I causing the blank row. If it is not something you need, you can delete it. If you need it, but it is not a plant, then either edit the object so it is not caught in the database criteria or edit the criteria so it is not captured. 2 Quote Link to comment
Amanda McDermott Posted May 3, 2023 Author Share Posted May 3, 2023 On 4/27/2023 at 9:28 PM, Pat Stanford said: Try and right click on the row header (3.xx) and choose Select Object. That should select the object and change layer and class visibility so you can see what I causing the blank row. If it is not something you need, you can delete it. If you need it, but it is not a plant, then either edit the object so it is not caught in the database criteria or edit the criteria so it is not captured. This sounded so hopeful, but Select Item is greyed out! Quote Link to comment
Amanda McDermott Posted May 3, 2023 Author Share Posted May 3, 2023 On 4/27/2023 at 8:25 PM, Peter W Flint said: Can you delete the row when you r-click and edit the table? No 😞 Quote Link to comment
Vectorworks, Inc Employee Katarina Ollikainen Posted May 3, 2023 Vectorworks, Inc Employee Share Posted May 3, 2023 @Amanda McDermott - this is an issue I sometimes see with plant reports - it depends on where you're taking the data from. Can you please send me a file with the report so I can see how you've set it up? 2 Quote Link to comment
Amanda McDermott Posted May 3, 2023 Author Share Posted May 3, 2023 9 minutes ago, Katarina Ollikainen said: @Amanda McDermott - this is an issue I sometimes see with plant reports - it depends on where you're taking the data from. Can you please send me a file with the report so I can see how you've set it up? Thanks, I'll email it to you. Quote Link to comment
Pat Stanford Posted May 3, 2023 Share Posted May 3, 2023 Add two additional columns to the report temporarily with formulas of =L and =C. Those will tell you the Layer and Class of the object that is showing in that row. With that information you should be able to track down the errant object. It is probably inside a group or symbol. 4 Quote Link to comment
Amanda McDermott Posted May 9, 2023 Author Share Posted May 9, 2023 On 5/3/2023 at 5:46 PM, Pat Stanford said: Add two additional columns to the report temporarily with formulas of =L and =C. Those will tell you the Layer and Class of the object that is showing in that row. With that information you should be able to track down the errant object. It is probably inside a group or symbol. Thanks Pat, sounds like a useful tip - I'll have a try and let you know how it goes! Quote Link to comment
Amanda McDermott Posted May 9, 2023 Author Share Posted May 9, 2023 On 5/3/2023 at 5:46 PM, Pat Stanford said: Add two additional columns to the report temporarily with formulas of =L and =C. Those will tell you the Layer and Class of the object that is showing in that row. With that information you should be able to track down the errant object. It is probably inside a group or symbol. This was very helpful, thanks, allowed me to set a criteria to exclude the layer the thing was on and the row has disappeared! 3 Quote Link to comment
