Jmoo Posted April 12, 2023 Share Posted April 12, 2023 Hello Is it possible to export a vectorworks file as a glb or gltf file? Quote Link to comment
0 Administrator Popular Post JuanP Posted April 12, 2023 Administrator Popular Post Share Posted April 12, 2023 @Jmoo You can add the export/import gltf format via the Workspace editor. To do this, you will need to install the Debug menu part of the Vectorworks Developer tools. Here you have the instructions: In Vectorworks, go to - Help menu>Install Partner Products> then Click on the Vectorworks Developer category>Debug Menu> Install and restart Vectorworks them Go back to Vectorworks and click on Tools>Workspaces. I suggest creating a new Workspace, and under the Menu category, you can add these options to the workspace. These options are part of the Design Suite workspace. We conducted a test, and it worked really well. 6 Quote Link to comment
0 Pat Stanford Posted April 12, 2023 Share Posted April 12, 2023 Or if this is kind of a one time need, just switch to the Designer workspace, do your export, and then switch back to your standard workspace. 1 Quote Link to comment
0 Jmoo Posted April 12, 2023 Author Share Posted April 12, 2023 Thank you @JuanP and @Pat Stanford. This has worked perfectly, appreciate your repsonses. 3 Quote Link to comment
0 mjm Posted April 12, 2023 Share Posted April 12, 2023 Just tried to locate the debug menu in partner tools. No joy. Is that because I am on Spotlight, not designer? 1 Quote Link to comment
0 rDesign Posted April 13, 2023 Share Posted April 13, 2023 45 minutes ago, mjm said: Just tried to locate the debug menu in partner tools. No joy. Is that because I am on Spotlight, not designer? You don't see it under Vectorworks Developer on the left hand side? (I'm on Architect) 2 Quote Link to comment
0 mjm Posted April 13, 2023 Share Posted April 13, 2023 @rDesign; grazia! I did install the debug menu and then had to dig down thru the workspace editor (eventually found thru the 'All Menus', not found under import / export). Have a great day 2 Quote Link to comment
Jmoo
Hello
6 answers to this question
