spettitt Posted March 29, 2023 Share Posted March 29, 2023 (edited) I add cable loom weight to the top of trusses with the distributed load tool. But sometimes, the end of the distributed load (the end placed last) ends up a long way up in the air above the truss. This was placed in top/plan view, with the red auto-connect highlight to start the placement and then clicked on a variety of different objects at the other end of the truss: 2D truss geometry, the toggle-able truss centreline, the end loci, various things. It doesn't always happen, but when it does, I can't figure out why. Edit: layer options set to Active Only, and I can still (sometimes) reproduce this Any ideas please? Thanks Edited March 29, 2023 by spettitt Quote Link to comment
Projx_CA Posted March 29, 2023 Share Posted March 29, 2023 Are you drawing in Multiple View Panes? I've seen this behaviour before, too. Quote Link to comment
spettitt Posted March 29, 2023 Author Share Posted March 29, 2023 2 hours ago, Projx_CA said: Are you drawing in Multiple View Panes? I've seen this behaviour before, too. Nope, just the one. Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted March 30, 2023 Vectorworks, Inc Employee Share Posted March 30, 2023 Hi Simon Is there anything that it could possibly snap too that is not visible? Can you send me a email with the file so I can take a look Gruße Jesse Quote Link to comment
spettitt Posted April 4, 2023 Author Share Posted April 4, 2023 On 3/30/2023 at 8:29 AM, jcogdell said: Hi Simon Is there anything that it could possibly snap too that is not visible? Can you send me a email with the file so I can take a look Gruße Jesse Hi Jesse, sorry for the slow response. I've just managed to re-create this so will mail you the file. Cheers. 1 Quote Link to comment
Moritz Staffel Posted April 7, 2023 Share Posted April 7, 2023 I think that the issue comes from your drawing order / snapping of truss. The first click (right part of the line load) did not snap to the truss. So it uses the elevation from the mouse click. Your second click snapped, because of this now for the second point the high of the truss is used. Quote Link to comment
spettitt Posted April 7, 2023 Author Share Posted April 7, 2023 Hi Moritz, The first click was the left-most end of the line, at the same height as the truss. For this click, I got the red diamond braceworks snapping line. For the second click (the high part), I clicked at the right-most end of the truss, at a variety of other bits of the truss - the end loci, 2D truss geometry etc. There was no roof or venue or anything higher that could be snapped to instead. I will make sure to get the red snapping line at the end of the truss as well. Thanks Simon Quote Link to comment
Mark Aceto Posted April 7, 2023 Share Posted April 7, 2023 Not for nothing but I typically draw distributed loads in Plan view with the Simplified Truss class visible. Haven't seen this issue before. Have you checked the layer elevation settings for the layer that you're drawing the load? Maybe that's bumping it up? Also, have you done the usual troubleshooting steps like pasting into a fresh file or starting from scratch (just the truss and loads) in a fresh file to see if the same issue happens there? Quote Link to comment
spettitt Posted April 7, 2023 Author Share Posted April 7, 2023 6 hours ago, Lunar Waneshaft said: Not for nothing but I typically draw distributed loads in Plan view with the Simplified Truss class visible. Haven't seen this issue before. Have you checked the layer elevation settings for the layer that you're drawing the load? Maybe that's bumping it up? Also, have you done the usual troubleshooting steps like pasting into a fresh file or starting from scratch (just the truss and loads) in a fresh file to see if the same issue happens there? Thanks. All Layer Elevs set to 0 in the file. I pasted the complete truss system in to a new file and re-created it. The show file had a stage referenced in, but the top part of the stage roof would have definitely been lower than the height the load went up to. Nothing was in the file up that high. Next week I plan to repeat this a bunch of times on a fresh file with a new truss system and see what happens. Quote Link to comment
Mark Aceto Posted April 7, 2023 Share Posted April 7, 2023 This is a long shot but also wondering if the 3D geometry is at the correct Z in the truss symbol definition? Or possibly something related to the truss plugin details (like the bounding box or wherever it’s called)? Maybe even the units of the truss record (similar to the long-standing L’Acoustics issue)? Quote Link to comment
