jpccrodrigues Posted March 9, 2023 Share Posted March 9, 2023 Hi guys, Can anyone tell if the export ifc works with site model? I'm working with an office that uses revit and the site model object is becoming a problem. Export directly a RVT file, the site model becomes a generic volume, that hardly "translates" to a terrain object within revit. The export ifc isn't working, tried a lot of variations on its settings, but the file comes empty. Anyone can give a help? Thanks!! Quote Link to comment
0 Ned Flanders Posted March 17, 2023 Share Posted March 17, 2023 (edited) Upon exporting an IFC file, you find that the model is empty, it typically means that the objects within the model didn't have IFC data attached. You can add it yourself though. I've never personally had to add IFC data to a terrain model, but my guess would be that you could attach the IfcCivilElement or IfcGeographicElement data and then try the export again. Edited March 17, 2023 by Ned Flanders Quote Link to comment
1 aage.langedrag Posted March 17, 2023 Share Posted March 17, 2023 Vectorworks has set the setting so that the Site Model is exported as IfcSite. This is wrong. IfcSite is geographic location and not an object. IFC files can only have one IfcSite and will therefore become a problem when we use several Site Models in the project. You must change the mapping on all your Site Models yourself. If you use IFC2x3 you should use IfcBuildingElementProxy while if you use IFC4 you should use IfcGeographicElement. Hope this helps and I hope Vectorworks makes this change in their settings. 4 Quote Link to comment
0 Poot Posted October 10, 2023 Share Posted October 10, 2023 I've recently opened a file in VW2024 with several site models that I created back in VW2021, and am also having an issue where only 1 site model shows up in the export. I've checked with both IFC2x3 (assigning IfcBuildingElementProxy) as used to work in VW2021, and IFC4 (assigning IfcGeographicElement) to no avail. I am sure opening an old file and converting to the new version is causing some issues...but can't really figure out why it wouldn't work. Quote Link to comment
0 Vectorworks, Inc Employee Mihail Rizov Posted October 10, 2023 Vectorworks, Inc Employee Share Posted October 10, 2023 Hi All, Please, see 1 Quote Link to comment
jpccrodrigues
Hi guys,
4 answers to this question
