201 -
Calendar
Everything posted by Mihail Rizov
Hi @zoomer, Thank you for your information. I'm attaching the IFC-exported file from our latest changes. A few things to note: - Please, do not attach IfcSite to whatever - an IFC file should have no more that 1 (one) IfcSite, it is added automatically (even if not present in the model) or it is the first DTM object in the layers assigned to Site in Layer Mapping/IFC Export dialog; - If you are not sure about IFC designation of an object - please, use IfcBuildingElementProxy. Another option is to choose Extended Vectorworks Model View (Export IFC Project -> Data tab -> Model View) - this will export any object that has 3D geometry as IfcBuildingElementProxy, so you don't need to bother with attaching IFC data; - When you attach IFC Data to a group - this means you want to create an aggregate IFC Entity - e.g. complex roofs/stairs/ramps can be created and exported to IFC in this way. In your file, there are multiple groups with IfcSite and many symbols with IfcSite inside - sorry, this does not make sense, so I detached IFC Data from your groups before the export. Regards, Mihail Rizov TEST_IFC_EXPORT.zip
Hi @zoomer, We are aware of that issue and we're working on it. Could you tell us did you draw all your objects in 2022 or the model was translated from 2021 or an earlier version? Thanks and Regards, Mihail Rizov
Hi @GatRed, This function duplicates the direct IFC syntax, like IFC.'IfcFurnishingElement'.'Name' - same as GetIFCProperty('IfcFurnishingElement.Name). Regards, Mihail Rizov
- 1 reply
- 1
Hi @Arielus, Coordinates and elevation in IFC are given in the site (IfcSite). You may find these settings in IFC Export dialog, Site Data tab. Regards, Mihail Rizov
Hi @archist97, It is not possible to open your file - http://piracy.vectorworks.net/IllegalFile.php Please, post the IFC file from AC. Regards, Mihail Rizov
Hi @Laura Stone, Sorry, we can't try this, because we don't have the full model - we have only the excerpt you sent here 😉 Export Site model affects only the export of DTM object that is representing the site (and its layer must be mapped to Site story). Regards, Mihail Rizov
Hi @Laura Stone, I can confirm that assigning materials in Revit works only if the geometry is extrude/solid and not in case of surface geometry. IFC sends the geometry as is and in case of Aligned Slab, the object geometry is mesh (surface geometry). Regards, Mihail Rizov
Hi @Laura Stone, We still don't have Revit 2021, but tried with 2020/2018 (used Improved IFC Import Add-In, as with the standard one nothing imported). In all cases, Revit shows the color of the geometry (from Vw) - the objects are imported as Floors with Import Symbol inside and you can assign material to both of them, but it always shows you the original geometry color. For me, the problem is that, actually Revit can handle well only solid geometry - we'll try and will get back to you. Regards, Mihail Rizov
Hi @Laura Stone, It seems to me, it's probably Revit Import problem. But, we have to find out the reason and use a workaround, if necessary. Please, send us a small excerpt from the model that illustrates the problem, so we can try export and import in Revit. (Also, please tell us the version of Revit that is used in your data exchange.) Regards, Mihail Rizov
Hi @elch, Could you re-post your files, as it is not possible to download them? Thanks, Mihail Rizov
Trouble exporting to PDF, DWG or IFC
Mihail Rizov replied to Matt Hagen's question in Troubleshooting
Hi @Matt Hagen, We are looking into this issue - temporarily, you can attach IfcSlab to them and set PredefinedType field to one of LANDING (if it is a part of a ramp/stair), ROOF (you know when), otherwise BASE or FLOOR (both are actually a floor, but BASE is a load-bearing element and as such is part of the building structural model). I'll notify you with our findings, when ready. Regards, Mihail Rizov -
Hi @Matt Hagen, I've reviewed your file and here are my comments, specifically about IFC (I can talk only about IFC): - You used a lot of extrudes in your model and you can't see them in IFC model, which is normal. IFC works with objects and each object consists of designation/type (defining the purpose of the object - like is this a wall/column/slab/roof/furniture/beam/etc.), data, relationships with other objects (like positioned in a building story, space, contained or part of another object, etc.) and geometry representation. So, an extrude might be the geometric representation of a wall, covering, column, footing, ... and this is why the user has to define what kind of object represents the extrude in question - this can be done by directly attaching IFC Data or using Data Manager class-based mapping. If you use Vectorworks plug-in objects - you don't have to do anything - they have the proper IFC designation and settings already defined. - You exported IFC4 file - at this moment, only Vectorworks and ArchiCAD have certified IFC4 export (IFC4 import certification not yet started). Even some applications claim to support IFC4 - you shouldn't trust claims. So, please use IFC 2x3; Regards, Mihail Rizov -
IFC export of a 16 story building takes over 45mins
Mihail Rizov replied to ptoner's question in Troubleshooting
Hi JMR, Please, try it with 2020. Regards, Mihail Rizov -
Hi David, As I promised, I asked about your question and here is the answer: "The menu style used in worksheets does not support separators. But this is an improvement we could consider for a future version. Hugues Tsafak Director of Product Development"
Hi David, My answers: - Item 3 - please, file a bug; - Item 2 - sorry, this is outside of my field of competence - I'll try to get an answer from the right person. Regards, Mihail Rizov
Hello, It seems to me, it will be better to have a simple example file attached, so I would be able to examine this closely. Now, to your questions: 1 - We plan to change that for SP3; 2 - Here an example will be of a great help; 3 - Except the need of an example file, as I don't know the content of the worksheets you mention, I'm not sure I understand this "you have to make a selection in the OIP first, or the worksheet selection does not seem to stick" - please, clarify with more details; 4 - Actually, the change happens in real-time, but the object(s) needs to be reset to show the change. OK, understood. 5 - Door is the plug-in object that comes with the English version of Vectorworks. Door CW is a plug-in object that replaces Door in the localized version for DACH-countries; Best Regards, Mihail Rizov
Hi @milezee If you can log bugs in JIRA - this is the preferred way. Otherwise, sharing files platform. Regards, Mihail Rizov
Hi @milezee, How could I get at least one of the files, in order to see what's going on? Regards, Mihail Rizov
Hi Zeno, Of course, Vw supports unique IDs for each object (GUID) and even at the level of components (like for the walls). The other concept is not exactly just a timestamp. It is IFCOWNERHISTORY - it contains not only the timestamp for creation and modification of the object, but also last user and application, type of modification, state and access of the object. It is possible in IFC to attach this to every object in the model, but I've never seen an application to support it at the level of objects - it is supported at the level of the project, so there is just one instance of the owner history and it is used from all of the objects in the model. There was a proposal to all IFC implementers (members of buildingSMART ISG) to make this support, but the main reason to not make it is, that this will make files a lot bigger and will slow down all the applications, along with the implementation costs. Regards, Mihail Rizov
Hi gester, Component functions were made to map component data in one particular workflow, which requires each component to be exported as a separate instance (ExportOptions->Export Separate Instances). So, during the export it returns the component data, based on the currently exported layer. Otherwise, it uses the core component data in the calculations. First, you have to remove the custom pset from Manage Custom Psets (IFC Data dialog) and then you have to be sure that a custom pset is removed from all data mappings. (if even one object uses this custom pset in its IFC Data mapping, then the custom pset will be recreated again) Regards, Mihail Rizov
Hi gester, AFAIU, we need to implement more functions in Data Mapping in order to fulfill your requirements - like, number/area of openings, getting material/material layers. For wall height, please, try object bounds functions. For windows, please, try object parameters RoughOpeningArea/OverallArea/ClearArea (area) and WindowMaterial/WindowFinish (you should provide materials in Windows settings -> Data -> fields 16/17). (record fields are in alphabetical order, because of user requirements) Regards, Mihail Rizov
Hi fhunt, There could be many reasons to not get all objects exported. Please, check first that your extrudes/cubes all have fill, then check your IFC Data - AFAIU, for this kind of work you should use IfcBuildingElementProxy for most of your landmark objects. Also, check that the classes are visible and "Export Visible Only" option is OFF. These objects usually are part of the Site (not building or building story), so map their layer to "Site", not to a story and check "Export Site Model" option. Regards, Mihail Rizov
Hi Acip79, We'll need the file (and Revit version) to be able to help you. Regards, Mihail Rizov
Thank you for pointing us to this problem! It is caused in the process of curtain wall's decomposition to parts - plates (IfcPlate) and frames (IfcMember) - currently, only geometry attributes are read. We are working on this issue. Thanks and Regards, Mihail Rizov
- 5 replies
- 1
- curtain wall
- ifc
(and 3 more)
Tagged with:
Hi Clem, I don't know what kind a "convention" is this, but this is the standard that is used in all software packages. Sorry, there is no "IFC CEILING" ;) (This site is the place where all IFC versions - 2x2, 2x3, IFC4, alpha, beta, draft, candidate release, addendum, TC - are published) Regards, Mihail Rizov
