100 -
Reputation
140 SpectacularPersonal Information
Location
Norway
Recent Profile Visitors
Rob Norris started following aage.langedrag
How to find objects not marked as "Closed" in OIP?
aage.langedrag replied to aage.langedrag's topic in General Discussion
Hi. I would like to be able to list properties in a Worksheet the same properties I can read from objects in OIP. Example; is the object Closed, number of Vertices. I can extract Perim and Area so why not the rest? -
Listing hardscape feature components in worksheets
aage.langedrag replied to yasin2ray's question in Wishlist - Feature and Content Requests
Hi @yasin2rayNot sure if you have received an answer to this question but also if I understand you correctly. Here is an overview of how I have extracted all components of the Landscape Area in the same list where the Landscape Area Style is listed. I have entered a copy of the codes I have used in the various columns in the database on row 3. What was important to me was also to list the IFC GUID on all the components. Unfortunately I can't find where this is stored in VW. I can't find any other IFC data on the components either. If anyone has an answer, I would greatly appreciate feedback. Otherwise, you should be able to list other properties of the components in this Worksheet. Also watch this film on YouTube from 2:31 min components in worksheets_v2024.vwx -
Daniel Ewald started following aage.langedrag
Site Model colour (3D Fill) won't change
aage.langedrag replied to Michal Zarzecki's question in Troubleshooting
Had similar problem. Not sure if this applies to your situation. A user had changed the Shaded Options to Textures and not Colors. The Site Model surface was always white. After much trial and testing. Found the error under Shaded Options. Switched back to Colors and everything is "Normal". -
Hi @Pat Stanford. Thanks to your previous explanation has helped me. Do you know if it is possible that this important difference could have been programmed into Vectorworks? It would be nice if we who use Vectorworks could get formula examples that correspond to how the program works here in Europe?;) Unnecessary use of a lot of precious time before finding solutions a little randomly in a forum.
@kwik I have not looked in detail at your challenges Knut, but have discovered that to extract m3 I ended up with a formula that calculates the area m2 and times the thickness of the object or the thickness of the material if objects consist of several layers. Got more correct quantities than if I tried to extract m3 from the object. This is on Landscape area and Hardscape objects. not sure if you can use any similar method.
Yes, in Excel, commas (`,`) and semicolons (`;`) are used differently in European and American versions of the program. - **American version:** Functions and formulas use commas (`,`) as separators between arguments. For example: ```excel =SUM(A1, B1, C1) ``` - **European version:** Functions and formulas use semicolons (`;`) as separators between arguments. For example: ```excel =SUM(A1; B1; C1) ``` This is because the European version of Excel often uses a comma as a decimal separator (eg `1.23` instead of `1.23`), while the US version uses a period as a decimal separator. The setting can also be adjusted manually in Excel under regional settings options if you wish to switch between these formats.
Hi, Try replacing IfcGeographicElementType with IfcGeographicElement as Kristian mentions. Or have you managed to find a solution?
jpccrodrigues started following aage.langedrag
All geometry that Landscape architects works with that is to be built should use curves with whole numbers of radius. No curves shall be divided into lines. The problem arises especially in our company when geometry is imported from other software such as dwg. All curves are then divided into countless lines, which is useless and makes the model very difficult to work with. When this happens, I ask those responsible to re-model the geometry in Vectorworks so that all curves and arcs have geometry that can be adjusted and changed. All arcs then only consist of three points, start, middle and end. This is where it is important to further control geometry with Simplification Tolerance. The first image shows geometry that is correct, while image 2 shows precisely the problem that the geometry has come from AutoCAD 2D. Sloppiness and inaccuracies that have worked for drawing production in 2D do not work when we work in 3D and BIM. Geometry must therefore be modeled again or changed so that all curves get the correct shape. Why should we allow mistakes to continue in the first place? 3D and BIM are also helpful in making us more precise and accurate.
Finished setting in VW2024 is probably 0.025. Setting is absolutely essential for the large model in VW to work and not collapse. After much use of this method in my models, I have used this general rule. 0.02 or now 0.025 - Early stage and standard. Then I work in more detail on how you want the object structure to be in the IFC for construction. NB. You have to work your way back and forth with some objects that have complicated geometry in order for the object to display correctly in 3D. Some solid objects in VW sometimes lose 3D geometry and then it helps to change the Simplification tolerance. Thin edges with rough settings mean that the outer and inner side of a curved edge suddenly have overlapping and intersecting geometry, which then becomes incorrect. Therefore, you sometimes have to go down 0.002 on certain objects while the rest can be 0.02. You also need to use setting to let geometry which is important to get right in IFC for build to model, edging of steel, get 0.002 while plant field which only specifies a 3D volume with plants has got 0.02. Very frustrating is that every time you have made changes to a landscape area, the setting is reset to 0. Completely unnecessary, unfortunately, so you have to make the changes again. I have built-in control views that color all objects after setting the simplification tolerance. All objects that have this =0 are red. This helps me quickly spot problems before I export IFC. Large models cannot change many objects at once. You must then select one volume at a time to change. If you have sent the landscape area to a site model that is on different design layers, a new problem. Then you must remember to have the Site model visible before you start making changes to the landscape area, otherwise the object will lose its height and lie down at sea level.
Length of railing and fence as a property in IFC?
Hi @Scott Campbell, Thanks for the reply where you show the Fence specific parameter. I keep forgetting that I have to look for these under "Expert formula". When I, who believe that I am quite interested in finding solutions, am "unable" to find this, I think that it should have been easier to find these parameters. Why isn't this simple in the "Simple formula" on relevant object types?????? The most relevant properties for all object types should be the properties that are always found. I also cannot see the length of the railing or Fence when I mark the object and look in OIP. Isn't this standard info? I greatly appreciate Vectorworks' great possibilities, but I am equally amazed at how much time I spend looking for very simple features and functions that I believe should have been visible to me without me having to test and search and search for help. When it comes to rounding off the length of the Fence in the example model, this must be an error in the program. I haven't done anything special. I only selected the standard object type from the library so I wonder if the program doesn't understand that the file is set with Units in meters? -
Hi @Scott Campbell. Watch this video and you will see that when I create a grade on Design Layer-2 and snap to Grade on Design Layer-1, the Grades on Design Layer-1 are split up. In many cases, we want to be able to see Grades from a Designlayer and snap to but not split up. 2024-03-11_12-27-21_v2024 - Grades.mp4
Big wish that Grades on different design layers can snap but not connect to Grades on other Design Layers. I work with several alternative solutions on different Design Layers. Very frustrating that Grades on Design Layer-01 connects to Grades on Design Layer-02 and divide that Grades . Suddenly, I have divided the Grades on another design layer. The elevations have also been altered and "destroyed". I wish I could have a setting that says that Grades should only connect with other Grades on the same Design Layer or that I could choose from a list which Design Layers can be connected.
