shorter Posted September 21, 2022 Share Posted September 21, 2022 Redefine view, in the contextual menu of the navigation palette is great. However, it needs also a menu command so we can give it a shortcut. 1 Quote Link to comment
0 Andy Broomell Posted September 22, 2022 Share Posted September 22, 2022 Perhaps an even better solution would be to make the "Save View" window more versatile (since it already exists in all relevant locations including the View dropdown, so a hotkey can be assigned). In this window it could easier to directly update existing views; currently you have to perfectly retype the name of an existing view from memory. The "View Name" field could start blank, as it does, if you want to make a view with a new name. But it could also have a dropdown arrow to choose from a list of existing saved views. So if you choose an existing saved view name then you're effectively Redefining it. (Perhaps the "OK" button changes to say "Redefine" if you're overwriting an existing view). This would allow you to assign a keyboard shortcut to the existing Save View command under the View menu. Just adding a bit more versatility to an existing command without complicating anything. Quote Link to comment
0 Andy Broomell Posted September 21, 2022 Share Posted September 21, 2022 Yes. It also should also exist in the Saved View dropdown in the view bar. Many folks don't realize this command even exists since it only exists in the Navigation Palette, while Saved Views are often activated with the view bar dropdown. 1 Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted September 21, 2022 Vectorworks, Inc Employee Share Posted September 21, 2022 There is a technical reason why this cannot currently be done: A Saved View is actually a command rather than a set state or mode. Think of it like a script. Once it's run, it's done. IOW, I Redefine View command would not know which view to redefine. Sure, we could store the last Save View that was run, but this could cause unintended behavior as well. I'm not saying we cannot ever do this, just explaining why it's not there now. 😉 1 Quote Link to comment
0 Andy Broomell Posted September 21, 2022 Share Posted September 21, 2022 26 minutes ago, Matt Panzer said: There is a technical reason why this cannot currently be done: A Saved View is actually a command rather than a set state or mode. Think of it like a script. Once it's run, it's done. IOW, I Redefine View command would not know which view to redefine. Sure, we could store the last Save View that was run, but this could cause unintended behavior as well. I'm not saying we cannot ever do this, just explaining why it's not there now. 😉 Couldn't a command initiate a pop-up asking which Saved View to redefine? It could auto-populate the most recently-used Saved View since that's likely the desired choice, though you could still choose a different one. Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted September 22, 2022 Vectorworks, Inc Employee Share Posted September 22, 2022 21 hours ago, Andy Broomell said: Couldn't a command initiate a pop-up asking which Saved View to redefine? It could auto-populate the most recently-used Saved View since that's likely the desired choice, though you could still choose a different one. Right. I just wanted to clarify that the problem is not quite as simple as one might think. Still not difficult but it would require that additional step for the user. Quote Link to comment
0 cberg Posted September 22, 2022 Share Posted September 22, 2022 (edited) I may be misunderstanding this feature request. While I like the the idea of having a menu command, I usually edit my views using the saved view pulldown menu at the top bar. EDIT: Now I see. You would like to redefine as opposed to edit. I guess I just make sure to remember the view name, which overwrites/redefines. Edited September 22, 2022 by cberg Quote Link to comment
0 shorter Posted September 22, 2022 Author Share Posted September 22, 2022 I appreciate Matt's point and that had not occured to me. It is probably the most straight-forward the way it is set up now. I am however, finding my wrists start to hurt after a while using the 'right click' on a mouse or mousepad! Quote Link to comment
shorter
7 answers to this question
