697 -
Posts posted by Vlado
@P Retondoi'll add this information to an enhancement request, so it is considered for the future improvements in the area.
Thank you very much, examples and workflow definitions always help
Hi @samgbickel, there is an option to disable the automated calculations, but unfortunately there is no UI for it.
To disable it, find the file 'IrrigationSettings.xml' located in "<app>\Libraries\Defaults\Irrigation". You can edit it there, or better copy it in your user folder, in the same location:
'<user_folder>\Libraries\Defaults\Irrigation' and edit it there. The difference is that if the change is in the user folder, any SP that you install will have this option, otherwise it would be just for the version you modify.
In that XML file, find the tag <AutoCalculation> and change it to 'false'.
This will disable the automated calculations.
Regards,
Vlado
1
23 hours ago, David Bengali said:
It looks to me that if a parameter is a Dimension or a Control Point, then indeed vs.GetRField returns the value with full precision. However, if the Parameter is a Number, vs.GetRField returns a string representation that is truncated at 8 decimal places, even if the value shown in the OIP has more precision. Not sure if this is related.
This is a different thing and it is intended that way. GetRField really returns a string, so it more picky of the precision. However, it is specifically implemented to preserve the precision of dimensions and control points. This is the same for both script languages.
@David Bengali oh wow, you have found a bug. I never realized this was there, yes the doubles are truncated when going from vectorworks to the python, and it is python specific.
Unfortunately, we just released SP4, so it will be fixed in the next SP and the next version.
Until then, you can use vs.GetRField to access the parameter values with full precision. it's a string you get back, but it has full precision number.
I'm sorry for the bug, it's a sneaky thing. Thank you for reporting it!
2
Hi @P Retondo
This is a known issue, and there are wishes to update this tool.
We have it high on our lists to update and improve the workflows with.
Regards,
Vlado
2
On 5/11/2020 at 4:29 AM, Bogdan Ciocan said:
I've been testing the connection ODBC and my database and can say that its working, somehow. But not with the DB from SQL which i want. My assumption is some SQL DB settings or restrictions.
If it works in general but not for a specific database, maybe there is a specific things about the SQL language of that database, like comma or quotations. We have a configuration file that can set these things up, as from Vectorworks perspective they are all the same, we just sent requests.
What's the database you are using?
On 5/11/2020 at 4:29 AM, Bogdan Ciocan said:On 5/5/2020 at 1:23 PM, Vlado said:So, now, if you edit a symbol definition, having nothing selected means that you are editing the defaults values that will be attached when this symbol is placed in the drawing. Noice that the 'Object Database Connection' is disabled in the context of symbol edit.
I've managed to this during my tests with another DB. I am using VW 2020 SP2.2R1 in german.
It looks you've found a place where the buttons should have been disabled but they are not. Symbols are not accounted for when exchanging data.
On 5/11/2020 at 4:29 AM, Bogdan Ciocan said:On 5/5/2020 at 1:23 PM, Vlado said:This can be possible with scripting (either python, vectorscript or marionette).
Which one would you recommend?
It's either say, all these use the same API.
10 hours ago, Bogdan Ciocan said:
I've been able to connect multiple objects (through attached records) to SQL via the key, in our case only just one. But when I'm trying to connect a single instance it doesn't work.
How do you do this? You surely have objects in the drawing for this?
10 hours ago, Bogdan Ciocan said:I am not able to understand why this doesn't work because in the resource manager (not in the drawing) the option to connect the default values is given.
Is there any constraint in order to do this?
The fundamental concept is that you connect a database to your VWX drawing. Then you define the format to be connected to a table, and establish which format field connects to which database table column.
Note, there is no data flow at this point, only connections that tells it how the data will flow, and where the data will be stored in both places: <vectorworks' format field> to/from <db table column>
Now, when you have a record of this format, which is the actual instance of a record, and can only be attached on objects in the drawing, then you have data, which is stored in a row of the data connected to this format. fields, i.e. db table columns, define how the data from that row will be exchanged with the record.
Now, if you insert this symbol into the drawing, the record is attached to that symbol, and you can use the Data pane button, or menu Tools -> Database -> Object Connection to associate a row of the db table to this record. Note you can do that on a single selection or multiple selection in Vectorworks.
The single selection will be like either add or select a row to provide the data for this symbol instance, where multiple will give you a chance to add or find rows depending on cirterias.
As far as I understand, you are trying to build up a library with prebuild values from symbol defintions connected directly to db. This can be possible with scripting (either python, vectorscript or marionette).
But there is one main question: if you add multiple instances of this symbol definition, you'll have repeating data...essentially the key will be duplicated, so several objects will contribute to a single row in the db table.
Maybe your data works that way?
Hi @Bogdan Ciocan,
11 hours ago, Bogdan Ciocan said:can be symbol definitions connected to databases in order to be used as a library?
The thing is that the option is given. This means that should work.
Well, technically, the symbol definitions are pre-set graphics that are ready to be placed in the drawing. They do not store any information, well they hold default values, but not countable information.
Then they cannot be connected to the DB as it holds actual data.
So, maybe your question is how to connect the default values of the symbol data to a database? But that would be strange as when you insert the symbol in the drawing, you can have several copies of the same data. Is that required?
What is the workflow you want to implement?
At the moment, a DB table for vectorworks is a Format and Record at the same time. Format represents the table and it's columns (the definition), and a record is a single row. This way, when you have several records of a format, you are dealing with several rows of that table.
11 hours ago, Bogdan Ciocan said:in the case that this should work, why am i not able to that?
Is it related to the issue that single symbol instances cant be connected?
Following my thought from above, if you have a record attached in the drawing, you can associate it to a single row from it's DB table.
So, if you symbol instance has a record attached to it, you can associate it with a DB table row and get/put the data there.
This works via the 'key' columns (one or several) identified when connecting to the database. They are used in the 'WHERE' of the SQL to identify a single row. this is the so-called primary-key and secondary-key of a table, and unique so they can identify a row uniquely.This means that your format needs to connect to these columns, so when you connect a record, it has a place to store the 'keys' to uniquely identify that particular row in the DB table always.
11 hours ago, Bogdan Ciocan said:in the case that this should work, can be multiple symbol definitions connected to the database?
Yes, selecting multiple objects and trying to connect them with the menu command, will allow you to use logic to associate the multiple objects to multiple rows in the DB table using pre-existing values in the keys.
You can also use the Data Manager to exchange data between records and parametric objects.
Regards,
Vlado
1
> clarify further on the process and its relationship to .pyc files, and how to ensure that the source code truly cannot be accessed in some way.
The python would compile the .py files into .pyc files before execution. This is part of python and always happens, it always executes the pyc files, and it has some smarts to not compile if the py didn't change.
The pyc files are binary files that are byte-code of the python code. I guess you can read more about them in the python documentation. As far as I know, it can be uncompiled but it doesn't restore variable names, comments, etc.
The process of encrypting a python plugin in Vectorworks consist of bundling all .pyc files into the vsm, vso, or vst files. It essentially, copies the binary files as is, one after the other in the vso, vsm, and vst file. This adds a little protection too as it's becomes one big binary now. Even though, if you really wanted, and analysed the bytes, you can figure it out.
let me know if you have more questions.
Regards,Vlado
1 hour ago, relume said:
But it is the reason why in VW python "sys.excecutable" on the MacOS/darwin plattform is pointing to the VW app, and why "pyhton" and "pip" are not exectuable on the command line inside the darwin VW app package/bundle (error : missing python image).
Well, the equivalent of the console command 'python' is a Vectorworks document script. You can execute pip-like stuff that way.
Also, note that python is very flexible in the sense of libraries. Perhaps you can try moving only the necessary stuff into the users folder: <user name>/Plugins
By default vectorworks will add that location to the search path of the python engine. So if you can isolate necessary needed pieces, you can provide them there. This is, of course, if there is no conflict with the exiting packages in the app bundle.
1 hour ago, relume said:But I have also to say that python 3.5.2 is for lot of modules a critical version.
I'll make it a point to update for the next release.
2
Hi @relume and @JBenghiat did you manage to get it to work?
First note that Vectorworks embeds the python engine, which means that Vectorworks is the python. So, if you just update your local python you are not really affecting vectorworks at all. So as Josh suggested, you can download the 3.5.2 on the side and manually copy it over into the Vectorworks bundle.
However, there might be problems with this. There are two sides of python: first it's the engine itself, it is linked, embedded into Vectorworks, and there is no way to change it unless we rebuild Vectorworks on our end.
The second part is the python built-in libraries. This is what you would be updating if you just copy them into the Vectorworks bundle. I guess it would work as long as python engine supports the new bundle directly. Of course you can try, just test it out carefully as not to have strange effects on other python based features.
Regards,
Vlado
@orso b. schmid i'm sorry, i've missed all these posts and the reference to me.
I'm sorry to hear that vectorlab is down.
It is absolutely possible to merge any information you have from vectorlab into the developer.vectorworks.net wiki. Also, i can give rights to anyone who is willing to support it.
Page edit requires logged in user, page creation requires admin.
User registration requires a request as we've seen lots of bots creating users and spamming the pages, but i create users for anyone who asks.
Unfortunately, I currently have no team to support it actively and produce nice examples. I'm working on this to change, but i cannot promise timeline at this point.
Again, if you have the db, or any set of articles from the vectorlab, i can merge it in.
@SeanR @maccadingo @loretta.at.large I just confirmed, the build is ready and it will be released tomorrow morning EST
3
hi all, there have been a problem with a different issue that the release was fixing which delayed the release.
At the moment it is scheduled to be released on monday, Dec 16
3
Hi @SeanR,
great. a patch for this will be released very soon.
Regards,
Vlado
1
Hi @SeanR,
this sounds like a known problem of Vectorworks 2020 SP2. The plant tool misbehaves when the user origin is changed.
can you confirm that it works correctly if you don't change the user origin?
a fix for the issue i'm thinking of will be released very soon.
Regards,
Vlado
3 minutes ago, Vladislav Stanev said:
That would be easy to calculate and set via a script.
I should clarify that I don't think this will compromise the accuracy of the drawing as the geometry wont move. It will be a script that calculates the adjust origin's lat-long based on the current user origin so the internal origin is at the same place.
9 hours ago, JeremyLondonRMLA said:
The options for Shapefile Import are the ones we're familiar with, but the User Origin has only become irrelevant to the Shapefile import in Vectorworks 2020.
This change was needed to make things more stable. You see the User Origin is something that is not fixed and can be changed freely, typically for adjusting the numerical values of the geometry.
Essentially relying on the User Origin was requiring the user to be aware of its significance and this was leading to misalignment and confusion.
So, in Vectorworks 2020 it's the Internal Origin that is the point that matches the GIS and CAD layers. It was there before, but it wasn't enforced as much as now.
Basically, the GIS layers (the layers marked as Georeferenced) are layers that belong to the Earth and they will move when you use the Geolocate tool. Then, the 'adjust internal origin' option will define the lat-long coordinate that the CAD layers will be placed at.
9 hours ago, JeremyLondonRMLA said:My understanding is that it's been possible for many years to move the georeferenced geometry toward the Internal Origin by manually entering coordinates under Geographic location and orientation of the internal origin in the document/layer georeferencing tab , and that the Geolocate tool is simply a new, user-friendly method of doing this.
That is correct, the Geolocate tool is just a visual way to set the 'adjust internal origin' options.9 hours ago, JeremyLondonRMLA said:However neither address the issue of an existing drawing from an earlier version of Vectorworks that began with a DWG import (with the default Center first import ... setting), followed by the subsequent import of a Shapefile, or perhaps the requirement to generate a Shapefile from the drawing data. In the office I work in alone, there are many hundreds if not thousands of existing drawings on the server which were created as above.
This sounds to me like an issue of setting up appropriate georeferecing as your old drawings are already located around the internal origin, but if the shapefile import doesn't match means the the 'adjust origin' options are not matching.
That would be easy to calculate and set via a script. Please contact me at vstanev@vectorworks.net and i can develop a script for you to use in these cases.
Regards,
Vlado
@ericjhberg message received. these are the things at the top of our list.
1
10 minutes ago, rDesign said:
Where do you need to log in to get more than just raster images - is it Vectorworks, VSS, or ESRI? Thanks.
You can log in to ESRI inside Vectorworks' new feature. Essentially, when you browse for service, you can log in to browse the ESRI's full catalog of services.
From those available services, we can only communicate the Image Layer services (raster image). The others are Feature Layer services, the shape file equivalents, which we will support in the future.
4
5 hours ago, HEengineering said:
I always wondered how to use this in 2017 but never really tried
Well, the main part is selecting appropriate coordinate system for where the project is located. Then locate your drawing and everything you draw will be properly georeferenced.
5 hours ago, HEengineering said:Is this something that would allow you to see right of way and property lines as well?
Not with the default maps. We only have satelite and map image services if you haven't logged it. If you log in, you can search for data in the area of the project.
But for now we only support raster images.
You can ask or look up the servers for your county. They often use ESRI, and you can type in the server address in the Vectorworks feature, and Vectorworks will request imagery from there. This also works with WMS servers.
1
7 hours ago, Mark Aceto said:
Speaking of the old fashioned way, I believe one of the benefits of this new method is access to more recent sat imagery, right? So it could be 3 months old instead of 3 years?
That's correct. Also, higher resolution images, elevation information, and other analytic information (raster images only at the moment in Vectorworks though)
1
3 hours ago, drcrescencio said:
I tried to use GIS in the VW2017 and it's extreme painful.
So, for the VW2020, the main idea is to set a CRS and use the ESRI Satellite Basemap?My philosophical view on this is that GIS is still as complicated, especially the coordinate system component of it. However, with the new feature, you can see if you are correct at all times as you can always use the Geolocate tool, and see how you drawing fit the globe.
It's like before you only had to infer to other files to find the mistake, where now you can see the background from the beginning and know when you made it misalign.
Your first step should always be to setup the CRS (coordinate system). This is especially true if you work with survey DWG files, which were the source of confusion and complexity before, as DWG doesn't carry CRS. This way whey you imported it in 2019, it would get moved to the center automatically and thus break the GIS.
In 2020, you should setup the CRS in Vectorworks, then import the DWG with the GIS option on, and your data will land perfectly on the GIS. And, you can verify this by using the Geolocate tool.
1 hour ago, Matt Overton said:Any Licensing / Copyright issue we'll need to deal with if the Imagery is used as an underlay to a drawing?
The Licensing/Copyright is always a concern when using geo images from services. This is true for ESRI or WMS servers. You should read the licensing for each service you are planning to you always and make sure you can use it in your project.
The default satellite and map services that we use from ESRI come with a restriction on image download.
This means that we will strip the images form the VWX file on file save. All other export or print will contain them.
When you open this VWX file back up, you'll be able to see the Geoimage objects and update them to get the images back.
So all the context is saved and the image can be just re-downloaded.
In an SP release, we'll make it so the images will be saved if you are logged in ESRI user.
Note, this is the same for the geo-image texture that we'll create for Site Models that have the option to texture with GIS image turned on.
2 hours ago, Mark Aceto said:What's the file size of the sat image?
see above about licensing. we'll not save those images in the main release. SP will make those images be saved when logged in ESRI user. Then it will affect the file size depending how much pixes are being stored, which you have control over, trading size for image quality.
4
Hi @Clint Alderman, our feature uses the ESRI's map services to request the geo-imagery. It is not associated with any of the other ESRI's products nor QGIS.
The feature is essentially asking for images a web service, and we default to ESRI's servers. You can also use WMS servers, and there are several free ones (note though, they still have some limitations on usage):
https://wiki.openstreetmap.org/wiki/WMS
You can experiment with ArcGIS Online: https://www.arcgis.com
This is essentially equivalent of what we have in Vectorworks, only we talk to image services only at the moment.
You can play around with this without making a user in www.arcgis.com, click on the 'Map' at the top.
Once you log it, you'll have access to more services.
Regards,
Vlado
1
Property Line Tool
in Site Design
Posted
Hi @Aspect_Design, unfortunately, this is not possible at the moment. Please enter it as a Jira bug so we can make it work.
The Properly Line has the 'Segment Record' format record attached to object inside, which allows you to report the segments in a worksheet. Also, there is a 'Curved Segment Record' one too.
Regards,
Vlado
