IanH
Content Count
791 -
Calendar
Everything posted by IanH
I use to upgrade every 2 years, taking advantage of the buy XX get xx+1 free available during a small window just prior to the next version coming out. That halved upgrade costs at expense of falling behind every other year - not a bad thing. Don't know if it works like that any more. But I just let my VSS slip. Will reevaluate Aug/Sep 2017 and see about buying VW2017 upgrade from 2016 and getting 2018 free.
You scale and annotate in the viewports. So a sheet can contain many viewports potentially with multiple scales. The sheet is just a repository for the viewports, you do very little directly on the sheet.
The VSS subscription expires at end of April 2016. Purchasing prior to this should (need to check with Computers Unlimited) give you access to exclusive VSS content without any further financial commitment if you should choose not to continue with VSS. The purchaser of this license will be eligible to extend the VSS subscription ensuring that their Vectorworks stays at the latest (and greatest) version as new versions are released. I would also like to clarify that this is for a Vectorworks 2016 Designer + Renderworks license. The earlier versions are licensed as part of the 2016 license as they were upgrades and are inseparable from the 2016 license so cannot be individually sold.
For sale, full commercial UK Vectorworks 2016 Designer + Renderworks (dongleless) license for sale. Remainder of VSS included (if transferable) - expires April 2016. I need to check, but I think I can also supply a dongle and discs/download instructions for VW 2008/2009/2010/2011/2014/2015 and of course, 2016. Please PM me to discuss. Thanks Ian
Anyone with any real life experience on this? Thinking of replacing my iPad 3 with a Surface but precise model would depend on viability of being able to run VW on occasional basis. Shame the M model didn't come with 8GB RAM for same price. I would treat it as a direct iPad replacement and anything extra it could do would be a bonus. Not a fan of having the fan on the i5/i7 models.
Unable to extract images from PDF created in VW2015
IanH replied to IanH's topic in General Discussion
Thankyou for looking and confirming that I'm not going mad. -
I've put a cleansed version in dropbox (32MB) for testing. Right click on any image and copy. Then try and paste into a different document. The size is correct but the content is blank/black. I've also attached the settings used to export the pdf. -
Thanks but the PDF was created in VW as an exported sheet later - no importing involved.The client wanted to copy/paste images from the pdf (by now exported to dropbox) into different apps but the images pasted as blank/black even though they were the correct size. The only app that I got to work was pdf viewer in the iOS dropbox app but then the problem was that i had to individually email 9 images/~40MB to the client whilst riding on a moving bus. -
Apologies if this has already been logged but search for PDF is too short to return any results. Probably user error but...in VW2015/RW on OSX 10.10 I created a large 300dpi A0 sheet with multiple hi-res rendered images and exported the sheet as PDF. The client wanted to copy the individual images into their own document. I tried to copy each image from inside various versions/platforms of acrobat reader but even though the correct image area copied to clipboard, the pasted image was either blank or black. In the end i managed to achieve this in the iOS dropbox app and paste to photo viewer then email, but it wasnt a great solution especially as i had to do it on a moving bus and knew at some point i would lose the 3G/4G signal. Any idea what is going wrong? I tried a selection of images, ranging 2MB to 16MB. I wonder if images were too large to copy, it was simply user error or a bug. Im sure i have done this in VW2011. I tried with default pdf export settings both with and without the bit to export layers. The issue was worked around but it would be nice to know for next time. Thanks Ian
I've raised it as a bug.
Yep. A continuous PITA for me every time I start VW2015 - i don't think 2014 is any different but rarely touch that anymore. May be of help, but since I deleted VW2015 from OS X Firewall allowed apps, the entry was not reapplied automatically. SO I manually added it (alone with CineRender) but this annoyance persists.
Vectorworks 2015 , 64bit and other technical questions
IanH replied to PVA - Jim's topic in General Discussion
Just read SP1 release notes. The lag issue wording reminded me of an issue that I am having and also had in 2011. I occasionally get a lag after an operation which goes away when i move the mouse. I think it got introduced after i had issues with my mouse. Cannot remember exact curcumstances of change in mouse other than i think mouse driver was updated. Possibly related to using a logitech mouse. Probably not related but thought i would mention it just incase it rang any bells. -
Just incase anyone stumbles on this, the bluetooth problem is an odd one where USB bluetooth 4.0 device goes into unrecognised USB device once a bluetooth mouse is connected then machine is rebooted. Oddly, it remains unrecognised even after disc is reimaged back to factory install - removing the mains and battery seem to be the only remedy. However, after a second machine had exactly the same problem, a contact at HP investigated further and tracked it down to the Intel Bluetooth 4.0 driver as shipped being the problem. Unfortunately the HP and Windows driver update programs both fails to detect a suitable replacement however the HP website does contain an update that when manually installed will restore functionality. Most odd that a onboard device can be knocked out and failure persists through a factory reset reimaging.
I just bought an HP Envy 15" TouchSmart for my son/family PC and I'm very impressed with it especially considering the price. Sounds like it may be similar spec to Jonathans. I had not realised that the i7 was a higher spec i7 MQ than the slower U or M versions found in many laptops acording to a review I read. Relieved to see though that my 3 year old MBP still gets significantly higher frame rate in Minecraft although its not a scientific comparison. With that, its worth noting that the HP power energy mode setting is significantly faster than the windows power save energy mode, the former is very keen to kick in the i7 turbo boost. Makes quite a racket and heat though so i turned HP mode off. Not tried the HP mode that detects it resting on your lap and runs cooler to prevent skin burns... The only negative is that bluetooth is intermittent from new, so its all packed up ready for a replacement.
Don't forget that Vectorworks is multi discipline and by virtue of its price point allows those in other disciplines that don't use it as a main tool access where they would otherwise be priced out. In this circumstance, time wasted on work arounds is negligible compared with finger trouble of irregular users. Happy though if you want to propose that the architect module is raised in price to fix the issues that most others don't care about.
Matt Panzer on this forum is responsible for it. I cannot fault his support for this product. Ive used it to good effect in conjunction with a 3D paint program called Piranesi to produce some very organic images that were used on The Alan Titchmarsh Show about two years back. I think Matt may still have a few examples on his website. Alas Vectorworks is no longer compatible at export level with Piranesi. It takes a bit of getting use to understanding vanishing points and lining up, but with good real life images (not all images are suitable for use with Camera Match), the end results can be fabulous. Well worth it if you need to composite a 3D model into a real world shot.
Have we now moved into the world where people no longer know what film sizes are? My son recently got his very first camera. A disposable with a film inside. Not sure where were are going to get it developed. Before anyone says, no you cannot use Photoshop. Yes. Its so you can match a shot to a film size/focal length.
If using referenced files, make sure paths are relative. But otherwise, I use to occasionally 360 files between PC and Mac and never encountered any issues.
Since moving to 2014, Ive found Select Connected Objects slow to display selection. Ive just realised that its probably not slow, just that it doesn't show the selected objects until you move the mouse slightly. Don't know what other bits that may also be similarly affected.
Have you tried custom with size 1 or 2 or does that remain too large. Ive not tried this in landscape area but have in revision cloud.
Just my 2p from someone who runs both Macbook and PC desktop - same monitor. Thankfully, with most VW licenses, you can run on either platform. A modern Mac or PC will both serve you well of you go with recommended specs. Some features of VW are better on PC (size of pallets etc), some are better on Mac (cannot remember what) - at least this was my view when running VW2011 and may be different under 2014. Apart from hardware preferences, don't under estimate any existing investment in software. I don't run Adobe on my Mac platform for this reason as the cost at the time of upgrading perpetual license CS3/PC to CS?/Mac was prohibitive and i don't use it enough to justify subscription model. Something that many overlook is the longevity of each platform. If you want to buy a version and stick with it, then Windows meets that requirements due to long life of its OS's. Ive got a probably 8 year old Windows XP laptop that will still run a modest project on VW2011. If you want to keep current and don't mind paying the premium for that, then the Mac yearly updates and VW VSS subscription will suit. OSX on Mac has about 2 year life span before you are pretty much forced to upgrade regularly. VW2011 that i was on is not compatible with laters version of OSX so before going with VW VSS, i was stuck on previous version of OSX with Apple rapidly removing support for apps and features on that version - they wont support TimeMachine backup issue that i have unless i move to latest version and im losing features from Xcode development environment by not staying current. Look at the OS compatibility matrixes to see the differences in lifespan of Windows/OSX platforms. You may even be caught out with software compatibility if going up a version or two of Windows however, i see you are on Win7 and personally would stick with that if you stay with Windows.
Unwanted hidden elements showing in design layers
Well it still does it under 2014. That was a waste of ???? -
Jim has confirmed this as a bug in <=VW2011 although is checking that its not caused by some default setting that changed in later versions. I guess that I should just bite the bullet, install 2014 and migrate the project to that. -
Long time since I posted on here. My client has recently moved to VW2014 from VW12. I am still using VW2011 and thats not going to change. Up until now, I have had some situations where I have imported my clients work and I have had ghost elements but I have normally been able to work out what the ghost elements are or not. These ghost elements are as a result of my client (in the politest possible way of saying) doodling on the drawing so they end up stacked and hidden below the main drawing elements. Unfortunately and probably nothing to do with my client moving to V2014, I have got a drawing where identifying these ghost elements is a bit more error prone than before. Which, going forward, could be a problem. I import my clients exported (from 2014 to 2011) drawing into my VW2011 with a referenced design layer viewport on to a design layer called import. As you can hopefully see from the images, when viewing this import layer (imported.png), the contents are as my client envisaged it. However, when I view the import layer (layers.png) as part of any other design layer or sheet, the ghost elements, such as concentric circles become visible. Its almost as if they become stacked in reverse order or I am losing object fill - the original referenced file all objects are solid white fill. If I open the original referenced file, the ghost elements do not show but can be highlighted with object selection. Is there anything obvious that I am overlooking that I can change to prevent this? Versions of VW are not going to change nor is my clients workflow so hopefully there is a setting that I am missing. Before anyone asks, all my clients doodles etc are in the same class/layer and my class visibility is normally show/snap/modify others and layer visibilities are grey/snap others and it makes no difference if I change these. Hoping that it can be explained by a senior moment... Thanks in advance Ian [img:right]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=10535&filename=layers.png[/img]
