jet
Content Count
65 -
Community Reputation
3 NeutralAbout jet
Rank
Apprentice
Personal Information
Occupation
Consultant
Homepage
www.icad.bc.ca
Location
Nanaimo BC
I have created a site model, and just want to drape the air photo over the site model, something i would do in sketchup. I can get the air photo to drape over the site model (sometimes) but the scale and location of that image is not correct. I have a simple exact area 1000m across and 2000m up, and i have an air photo that has been cropped to exactly 1000pixels by 2000pixels… I have read about and tried the ‘Attribute Mapping Tool’ but each time i use it i get inconsistent results. I get predictable results if i do this to an extruded rectangle, with the Attribute Mapping Tool, i can move it around etc... but not with the site model. Any ideas? Jim Macbook Pro 2.2 GHz Intel Core i7 16 GB 1333 MHz DDR3 AMD Radeon HD 6750M 1024 MB OS 10.11.1 Capitan VWD 2016 SP2 w/RW
angle of line measuring zero as east? can i change to north?
jet replied to jet's topic in General Discussion
True, but what i have is a series of lines that i have to give the length and angle for. Lines that i want to be an angle of 270 degrees are measuring 0. Another example a line that i want to measure 180 degrees is measuring -90. -
I am doing a survey plan, and measureing the angle of lines, i want 0 deg to be north, currently 0 is east. I am sure there is a way to change that, but i can't find it! any help out there would be appreciated. cheers, jim using VW design series 2015 on 2011 15" MBP
Often with files from other CAD sources, there are duplicated lines in the exact location. Is there a way to select duplicates or erase duplicates? cheers, jim vw 2015 design series
Could anyone point me in the right direction, document or tutorial... I want to have a symbol or object that i can drop on the drawing, and it is sized based based on a few variables the user can change. for example a table, that the user can enter the length and width... VW 2015 designer series
Can anyone point me in the right direction, i want to make a series of dynamic symbols... a simple example would be a table. To make a symbol that the width and length are based on variables that can be changed. jim VW 2015 designer series
is there an email, the file is 80mb +
I have created a site model, i want the index contours labeled. All that is labeled is the 0m contour? what am i doing wrong? please see attached... cheers, jim 15" mbp 2.2 ghz i7 16 gb ram VW design series 2014
yes, but not really a solution. need to have annotations on multiple viewports and sheets. very frustrating... cheers, jim
Please say this has a fix... i come across this a lot, i have a rotated view, and i can not use the collouts, they ONLY work when the view is NOT rotated. In the rotated views, they will not stay horizontal... any ideas? Jim VW 2014 design series - sp 4 MBP 2.2 - i7 with 16g ram with ox 10.9.3
I have a fairly simple site, and created a terrain model from 3d ploys (contours) The generated contours look good and reasonably accurate, but in the 3D view, the terrain is inverted? The low points are high, and the high points are low... It looks inverted or mirrored. Again the contours are correct... any ideas? Jim VW 2014 design series MBP 2.2 i7 16 ram os 10 (Maverick)
Yes, the area i am working on is cropped by the viewports. But the file size of that pdf (just a portion of the overall) is huge. cheers, jim
I can covert to an image file, no problem. Do i really have to crop it for each area i want to plot... The project area is very large, and i bounce all over. cheers, jim
