Alexey Trebukhin
24 -
Retain object overlay while moving
Alexey Trebukhin replied to mahmoudsmonem's question in Wishlist - Feature and Content Requests
Hi Mark, is it possible to turn this function off/on? Couldn't find that. 😞 -
Hey folks! When im trying to move+copy truss segments to connect it to the boxcorner truss it sticks to random magnet. Please find video in attach. Запись экрана 2021-10-03 в 20.56.10.mov
@JBenghiat Thank you! 🙂
Hi! Anyone knows how to calculate nurbs surface area? Convert? Report? Data Tag?
@TomWhiteLight Hi! If I have the same problem in viewport GL rendering? Unchecking VGM didn't help.
@patrickbellll hi! %) I used scale before I found grouping. 🙂
Hoist Display Options - Where did they go in v2021?
Alexey Trebukhin replied to Mark Aceto's topic in Entertainment
Hi! Did anyone managed how to add point load information in Hoist data tag. Or now it's possible only in Braceworks? I faced with the issue I cannot get how to solve.- 23 replies
- braceworks
- hoist tool
(and 1 more)
Tagged with:
@markdd thank you for clarifying this. I usually have different light setups with the same units inside but different positions. As I mentioned before now I'm struggling with vertical and horizontal rig for the same lighting device in 1 setup. And I was just wondering if there is a way to simplify the workflow without multiplying the same lighting device for different positions. 🙂
- 3 replies
- spotlight 2021
- lighting device
(and 1 more)
Tagged with:
Hi all! Since 2019 I mentioned that there is option to make a few different 2D symbols inside 1 hybrid lighting devise symbol in "Edit 2D components" menu. But I couldn't find any chance to switch between them inside document. For example: I have 2 different rig types for 1 lighting device 1 - is vertical 2 - is horisontal Now I have to duplicate my lighting device, change its name and 2D Symbol. And in that case it works: But I hope I miss something and there is option to switch between 2D Components in one Hybrid symbol without duplicating? Any help highly appreciated.
- 3 replies
- spotlight 2021
- lighting device
(and 1 more)
Tagged with:
@robertino hi! Is this what you are looking for? If If yes, use: =IMAGEBYDATAVIS('data visualization name') in first column.
Lighting device weights and worksheets
Alexey Trebukhin replied to markdd's topic in General Discussion
@markdd Thank you! It works perfect! And I found my mistake! 🙂 -
@markdd Hi! How did you manage this formula: "=VALUE(SUBSTRING('Lighting Device'.'Weight', ' ', 1))" to work? I'm struggling with text to numbers issue for "Wattage" and "weights" field since 2019! 🙂 And it seems for me that you found the solution? What am I missing? Thank you in advance! -
Weight and wattage counts for hanging position issue
Alexey Trebukhin replied to Alexey Trebukhin's topic in Entertainment
@jcogdell thank you! I tried before this function and it works if you have only numbers in the field, but if you have units like "kg" or "W" in the same field, this function doesn't work! 😞 I couldn't find formula or function that could split units and numbers and put it in 2 different fields. Is there something similar to Excel function "Text to columns" in VWX?
