rvanhees
Content Count
33 -
Community Reputation
0 NeutralAbout rvanhees
Rank
Greenhorn
Personal Information
Location
Netherlands
Recent Profile Visitors
Hi, This is the original record. The red circles were to clarify what I meant. It is final Quality Render, and i have no ceiling.
Hi, When I make a rendering via renderworks camera tools and then create vieuwpoort with a number of spots, I get a kind of reflection on the floor. The texture Tile granite is in front of the floor in Render. How can I get it out? / What am I doing wrong?
Hello, Just started with Vision ... If I transfer my drawing from VW2020 to Vision2020, the lamps go to a zero point. I have already found this on the forum. Is there a way to rotate or aim the lights in Vision without a lighting desk on it? Or another easy way to aim the lamp, for me its now just for the visualisation. Tnx
Hmm very strange, I open now my file again and its gone .... Think it's a bug ...
Hello, For some reason I have a 2d laptop in my drawing that I can't get removed ... It is in the None class, if i put the visibility off it is gone. (tried all other classes) In Open Gl you see the 2d version. (I think it was created after adding the laptops at the reception desk, 2D plan you don't see them ) How can I remove it?
Hi, I'm using the Tool set > Table and chairs. There is no option (Shape) to choose: round. Is there a easy way to get round dinner table?
Who can help? Amateur user of VW2019 Spotlight. My worksheet does not display the correct number. I made several designs, and most of the time he did well on recalculation. If this did not go well, it would have been resolved to create a new worksheet. Now I have a design where recalculating and recreating a worksheet doesn't work. I'm curious what I have to look at to solve it. In design 15 objects in sheet 16 objects. In this case VW counts 4 x FD34 200 but there are only 3 in drawing. Thanks in advance. Rob. G-3-333.vwx
Hello, Is there a way to make a report of only the viewport? Now the report gets everything of the design.
@JustinVH Hi Justin, i don't get it, try everthing put ratio 1:100, have made different sizes .... Also strange if i put the VW Colorbars 1x1.89 is works perfect. Try to find out wat size it is, try to copy it ...
@JBenghiat Hi Tnx for the answer, it works.
Hello, I made a floor in VW2019 for a stand. From Top/Plan: 1) Rectangle tool 2) spotlight- architactual - floor 3) tab render - texture - wood The problem is het puts the texture under see picture 3 I tried flip / rotate etc ... Is there a easy way, or what did i do wrong?
@JustinVH Hello, i dont see the check boxes "repeat vertically" and " repeat Horizontally" ..... and set by image does not work. See the file. 4006223 - BOOM - EMS.vwx
Hello, I want to put a logo on a screen, but whatever I try, whatever dimensions, he continues to publish in the box. What do I wrong or what should I do?
@JustinVH Other question. How can I turn the doughty, I have tried everything (I think ...) flip, rotate and rotate tool Thanks.
