LCarm
37 -
Reputation
10 GoodPersonal Information
Occupation
archtiect
Homepage
www.ecohousearch.com
Location
United States
Recent Profile Visitors
670 profile views
Callout Leader Lines, Text Alignment, and Arrow Styles - What a mess...
LCarm replied to Shortnort's question in Troubleshooting
I am getting a 1" offset on the slab using the model massing tool. Where is that setting? I want it flush with my walls but can't figure it out unless I only show roofs as floors. Thank you VW pros!!
I agree, my pet peeve is messy drawings, I have all notes, keynotes, etc. lined up left justified. drives me crazy, anyone know an easy fix for this? also, a "CALLOUT STYLE" would help so that it doesn't have to be revised every time and can help drafters do things the right way. and...does anyone know how to change the "width factor" of text? -
VW Cloud Services and Google Drive
LCarm replied to tpenna's topic in 3rd Party Services, Products and Events
100% agree, please help us Google Workspace clientelle... I will keep trying and see if it gets fixed -
We just figured out that more than one person can open a file without the typical "read only" or other warning (leading to work not getting saved). We recently moved to google workspace with google drive for desktop running our files through the shared google drive. Any fixes?
Hello all, I am having a hard time using the site modifiers tool in Vectorworks Architect. My intent is to place a vertical edge using the Pad with retaining edge mode, but it doesn't give me the option to establish a vertical edge. Is there a setting for this tool that creates a vertical edge instead of a sloped "terrain" edge. I have attached an image with the settings I am using. Thank you very much.@Wes Gardner @Pat Stanford
Looking for in-house or consultant for project coordination and/or project management for small architecture firm in San Diego. Projects include multi-family and single family residential, mixed use, affordable housing and luxury coastal projects in San Diego and Southern California. Tend to project needs from conception to construction completion while addressing sustainability. Produce conceptual layouts, full design development, management of construction documents, materials selection, specifications. Working within budget and schedule parameters. Modeling / design and direct drafters in Vectorworks Currently accepting applications and conducting interviews Please send resumes including salary requirements to liz@ecohousegreen.com
Any luck in getting "Shared Drives" google workplace drives integrated with Cloud Services? -
@jeff prince Thank you! 💪👊👈 Saved this office from madness! 😵
Service Select: Hyperlinks in Vectorworks
LCarm commented on administrator's calendar event in Community Calendar
Is there a way to universally change to inches instead of points for text heights? My brain works in inches but the other problem is that we have the text to the correct height but it is not printing correct nor when measured is it the correct height. For instance, 3/32" height (entered in inches) = 6.8 pts at 1/4" scale viewport, the text should measure 4.5" and print to 3/32" but it measures to 3.243" and prints smaller than 3/32" Is there some other international point system VW goes by? I'm baffled and incorrect text height is a big pet peeve of mine so I'm driving everyone crazy!!!
@Pat StanfordIs there a shortcut key to toggle on and off "Object Retention Mode" in the Move by points tool? Also Tape Measure? Or a way for me to add one to my workspace? Thank you!! (old school, prefer keys as much as possible for speed 😏)
@Nikolay Zhelyazkov Thank you. Oddly enough it has not been crashing lately. The driveway is turned on and it is odd that it shows it as it is rendering but the final does not show it. I will remember to do a screen recording next time I have this issue. (hopefully does not happen!!)
I figured it out.... my linetype was set to fence! 🙃
I have my floor layout as active and active class as none. Yes, I was working on this file and everything was going swimmingly and then I inserted a 2nd double patio sliding door and the entire drawing started giving me loci when drawing new rectangles or inserting doors. I closed and restarted VW and they were still there. You can see in the second clip, the first slider I inserted has no issues, that work was done yesterday. Did I accidentally turn on some setting I'm not familiar with? I have not tried printing yet but it is distracting while modeling. Im attaching the file for reference. Thank you! 20.10.21 G ave 839 v2021.vwx
until
