Shortnort
198 -
Reputation
31 GreatPersonal Information
Occupation
Architect
Homepage
https:\\nortonarchitect.com
Hobbies
genealogy, history, woodworking
Location
United States
Recent Profile Visitors
1,126 profile views
Thank you, but my issue is that my Sheet Layer displays properly, but it doesn't print out what is displayed on the Viewport. This has happened once before and a solution was never forthcoming. My storefront symbols appear correctly in ALL viewports, including elevations, perspectives, etc. The storefronts print in other viewports, just not any of the plan related views.
Well - this is happening again!!! I have tried everything I can think of - even using version 2023... Still an issue - and I need to publish for Permit Review, of course. The first pic is the published version of the Sheet Layer on the right.....
Can someone tell me how to NOT see and print the Cut-out "symbol" from my storefront doors? I am just leaving them for now. I may have to whitewash over them if I can't figure this out.
I have a similar issue. I have a Storefront style door with frame inserted into a Wall. I need the door to be offset, but it only allows me to insert to center of wall, left edge of wall or right edge of wall. I am trying to match the existing conditions of the rental space and this is becoming quite frustrating. I never had this issue before and am confused as to how to correct it. Do I need to "unstyle" it? Too much time has been spent trying to resolve this. Hopefully someone has a quick fix.
Wall Closures - VW2024 Workflow, and transitioning files from VW2023
Shortnort replied to E|FA's topic in Architecture
I could never figure it out in 2023 and can't figure it out in 2024. I have spent too much time already trying to get this to work. I downloaded the sample files, but still didn't make sense to me. More than likely it is very simple, but I am old with limited brain power and need visuals to assist me. -
Doe anyone have a simple way to determine the number of plumbing fixtures required by IBC? I have been using a spreadsheet in the past but got a wild hair and thought I would try incorporating the Spaces in a Worksheet. It would be simple, I think, if the Space Types Additional Data fields would allow formula. Perhaps they do, but I have not figured out how to do that. The formula is treated like a text string. As shown below, there are several different Occupancy Classifications, which in turn have different Plumbing Fixture requirements per IBC. This example uses my Occupancy Load Worksheet as a building block for the development of the Worksheet I am hoping to have. Plumbing Fixtures for Church Assembly is a simple formula: Water Closets for Males - 1 per150 and for Females - 1 per75. Business is more complicate: For first 50 occupants - 1 per 25 and additional of 1 per 50 for remainder over 50. Any assistance in providing a possible worksheet layout and cell functions is most appreciated.
Not to criticize, but when I query a drawing for the Resource location, The highlight is extremely WEAK. I really have to look closely at the menu to see which item is highlighted. Time is Money.
- 99 replies
- 1
- vectorworks 2024
- new ui
(and 1 more)
Tagged with:
How do you delete the ground plane as suggested?
This is not really applicable to this discussion, but I am having much difficulty getting my site model to be seen in Twinmotion. I have tried direct link, exporting, etc. TM loads the file, the folders show them loaded, but there is NOTHING THERE. Any suggestions? Must I explode my model shown below? Grades vary from 1055' to 1074' roughly.
Export Unreal Datasmith
Shortnort replied to Wohnraumdesign's question in Wishlist - Feature and Content Requests
Thank you. It wasn't in my default pallet, but I customized and got it. Thank you for your help. -
Excuse my ignorance, but how to I activate Datasmith Link in VW24? I can not find it anywhere. So, I am currently just exporting to Datasmith, but what a pain when making revisions to my VW models. -
Dave, I reinstalled VW24 and VOILA!!! Issue solved. Thank you so much.
Dave, what is the best way to reinstall to insure no data files are lost?
My graphics card is fine. Also, there is NO PROBLEM with textures in VW 2023. Perhaps the latest update has a glitch? Processor AMD Ryzen 5 5600X 6-Core Processor 4.20 GHz Installed RAM 64.0 GB Graphics Card AMD Radeon RX 6600 (Latest driver installed) System type 64-bit operating system, x64-based processor Pen and touch No pen or touch input is available for this display Is my machine adequate for VW2024?
