HWood
33 -
Reputation
9 NeutralPersonal Information
Location
United Kingdom
Recent Profile Visitors
Hi, The guidance suggests the legend is created automatically on the annotations layer when you apply a data visualisation to a viewport - but it never appears for me anymore (it used to). Is this a known bug?!
my clever colleague worked this out, so I hope it helps others. 2019 VECTORWORKS Useful Notes - areas calcs.pdf
I am trying to use Data Manager - I understand the principals of needing objects to have records attached. But how do I add these to a wall style for example? The Vwx training on the subject just says - 'Attach a Custom Record...e.g. WALL DATA - parameters include Fire Ratings' but now how to add that Custom Record to the style.... I currently have to select the wall(s) and then go to the data tab and attach the record I want, which can easily lead to errors and is rather time consuming... Regards
it would be really useful if design/drafting view could have colour by layer turned on, but when you move to the viewport it is turned off....! keep having to switch it on and off.
partial workaround for the plan attributes - just texture the sides of the extrusions.....but still...!
e.g. section style of grey fill and thick lines - when used on section viewport this is not seen - just think lines and white fill....or in plan when in the drafting view - class characteristics not visible, although the attributes palette shows them correctly. I've had this slightly resolved in that the 'plan' characteristics apparently only appear if you render the plan as OpenGL - this seems very odd, to have to render all plans just to have the existing walls in grey with a thick line weight....but then if you want the wall to have a texture in 3D you can't have just grey in plan???
thank you @Domas we have tried this but it hasn't helped unfortunately. We are on the latest service pack for 2019. We have also tried opening it in 2020... 😞
Hi All, Is this a known issue? We've had parts of drawings disappearing for a few weeks now. Particularly from larger files, but both 3D models and 2D draughting. Sometimes the drawing is missing from one users computer, but visible on anothers. Sometimes we can see the orange box when we hover over it , but even if we click into annotations we can see nothing at all. The data is never recovered and we have to draw it again! Very concerned.
How do I "pull out the profiles and use them as Customs" please? We are struggling because we need to add UC203x203x86 and can't figure out how to add a custom shape!
- 3 replies
- structural member
- universal column
(and 1 more)
Tagged with:
I can't seem to get rid of the line between levels/storeys - see attached. These are different wall types but they are aligned correctly in plan. there should be no line as it is a continuous brick elevation.
Project Sharing: Save and Commit option when exiting
HWood replied to Mickey's question in Wishlist - Feature and Content Requests
other than shouting across the office, is there not some way that one user could request that another user 'saves and commits'?!! I.e. a pop up notification on the screen? And when we add comments during 'save and commit' these do not seem to be given to the other users... -
How do we do this? We include them on our window schedules usually. Currently we can't even select the rooflight in the roof, let alone add an ID tag and all the associated data tags required to populate the window schedule report....Thanks.
Hi, How do I assign a name to a user defined field in the door or window style options pallets? Currently they are User Field 1 etc....but that means that when I generate a door or window schedule report, they have incorrect headings/data - and it is hard to remember what each UF is for! Thanks...
