DanJansenson
    316
Reputation
370 Spectacular
1 Follower
Personal Information
  • Location
    United States
Recent Profile Visitors
  1. Thank you, Pat, for letting us know.
  2. I have encountered this as well. Restarting VW (and sometimes just closing and re-opening the file) brings things back. Seems to occur after working on the file a while, with several other programs open at the same time (especially Apple Mail).
  3. If it's a static render, you could also Convert Copy To Lines with Hidden Line Render, and then assign the resulting lines to a dashed line. Render the original view in Shaded Render, and then place the HLR/dashed lines version directly on top.
  4. On the Mac, two interesting apps are Waterlogue and Photosketcher, both of them very inexpensive. They can produce quite nice handmade-appearance images from RW images, and especially when output from each is stacked back in Vectorworks to produce a combined image (and in the example at the bottom, combined with a VW Hidden Line render). Not to everyone's taste, but still has potential, I think.
  5. This is a wonderful technique, using image props behind the Section Viewport line. And it works not only with elevations, but with perspective views as well, with image props behind the camera position.
  6. For the curved walls there is a work-around in HLR, though it's inconvenient. Create a very thin external component for the top-most wall, and extend the bottom of it to the bottom of the stack.
  7. I think this may have been posted here already, but just in case it wasn't: https://architizer.com/blog/practice/tools/free-material-textures/
  8. Thank you for everything you've done, Jim. Best of luck with your next phase, and hope to see you back as soon as possible. Dan J.
  9. OK thank you, Jim. But in any case, the GPU spec is basically left out of this particular consideration, focusing more on the speed and number of the cores, yes?
  10. Jim, If the chokepoint in my setup right now is Hidden Line Render, then a big investment in a faster CPU(with more cores) would be better than a big investment in a better GPU, am I reading this correctly?
  11. Hey, I have a old laser printer for sale. Cheap! Also a pair of shoes. Contact me for the best, discounted price!
  12. Christiaan, if you have a specific laser-cut pattern you'd like to try, send it along and we'll see about creating a sample texture for it. Dan J.
