Judy Cosgrove
15 -
Calendar
Everything posted by Judy Cosgrove
thanks for that - I just tried "unfold surface" on one of my objects, but didn't work as it was a compound curve ...but "tool tip" says it would work on a surface modified in one dimension, such as the surface of a cylinder. would be better if I could start with a flat shape and move it around without distorting, but you are correct - there would be so stretching for sure...I would have to approximate, and the fabricator would need to factor that in. I would like to do a model that is "build-able" and not one that is misleading. Its a conundrum.
zoomer- is it possible to not distort the size/shape/volume/area of the nurbs surface when moving it around? How do I "lock" the shape? I want to be able to start with a flat material so I can draft it later for the fabricator.
Help please! I would like to model flat sails, possibly with slight curves cut into the sides, and want to be able to have that as a flat pattern for the fabricator. I also want manipulate the sails in 3D without distorting it, so I can see what it would do if twisted or bowed etc. Some of the sails may need to be more than 3 or 4 sides... How do I accomplish this in VW? .... The reverse would be to model something I like, then flatten or unfold the sails to get the patterns, but don't that is possible in VW? any tips? thanks in advance- JC
Curtain Wall tool drives me crazy. In the past whenever I would try to edit one horizontal up or down, the rest of the horizontals revert to some default, and I would have to re-do everything. More recently I stopped using it and create them with extrudes.
Real world tools for working in 3d views
Judy Cosgrove replied to Kevin McAllister's question in Wishlist - Feature and Content Requests
Andy are you coming the the VW use group meeting 2PM on Saturday at the ADG? Hope to see you there. -
YAY! thanks Andy!
did you try increasing the resolution (DPI) in the sheet layer? Also try increasing the CAMERA resolution/dpi in OIP...
Vectorworks User Interface Overhaul
Judy Cosgrove replied to Thomas Wagensommerer's question in Wishlist - Feature and Content Requests
I like the colors - makes it faster to locate things. -
How to get rid of unwanted artefacts in OpenGL?
Judy Cosgrove replied to sashen's question in Troubleshooting
I love OpenGL!!! -
@Maho555 you may have to change preferences again if it happens again... which it did for me. I have not updated to Mojave either... holding off til the coast is clear!
The same "ghosting mirrors" thing was happening on my iMac Pro when I would scroll- zoom in or out...I would have to restart. I was able to fix it by changing preferences for navigation graphics to "Best Compatibility" .
I am using 2019 with Mac OS high Sierra... .I have had trouble with panning and zooming in viewports. It was creating ghost images. Pat Stanford suggested I change my graphics preferences which I did. That seems to have solved the problem. I will heed the warning NOT to upgrade to MOJAVE just yet.
Great- Thanks!! Is that an add-on or plugin? How do I get that?
- 4 replies
- window
- custom sash options
(and 2 more)
Tagged with:
How do I get a 4" wide sash around the perimeter of of window opening using the custom sash options? When I try to add it, I get 4" sash between every muntin. I made the muntins 4" wide to simulate the sash pattern in between and thats not right either. Also when I try making the jamb 4" wide, to simulate a 4" sash all around, it does not sit in the 12" thick wall properly. This is an existing location with a wood sash pattern, but should I just simulate it with the CURTAIN WALL TOOL instead? Thanks Judy d
- 4 replies
- window
(and 2 more)
Tagged with:
