elepp
253 -
Everything posted by elepp
2020 Teaser Tuesday - Live Data Visualization - Vectorworks 2020
elepp replied to JuanP's topic in News You Need
Hi, to my knowledge at the moment, it's only possible to have a legend showing the colors automaticly on the sheet layer, but not in combination with a colored symbol. Maybe a wish for 2021? -
Hi, so far we are quite happy with this new tool. One thing we would wish for though is the possibilty to pull informationen from multiple objects into one data tag. Example: We always write next to our apartments the total square meter of the whole apartment. So far we do it manually, or sometimes with a mariontte object. Both so far not ideal. Would be nice to select multiple rooms and have the data tag pull the square meter and maybe the apartment number, or any other field for that matter. Edit: The data of the data tag should be visible in the OIP. Add the moment you have to double-click a data tag to be able to change the data. Why is it not available in the OIP, where i can add data for all other PIOs. Than I could as well select multiple tags and change the data in the OIP for all of them at once.
Hi folks, can anyone tell me what the most influential factors are regarding file referencing. I have to files the source and the target on our server. The source file is roughly 450 MB big and opens in Vectorworks 2019 in 15 sec. This file is refernced into the target file. If I update now the source in my target file it takes 7:40 min to update this file. That is beyond acceptable. The path is set to relativ. The Checkbox at Copy/Cache he refrenced file is not set, even though in my test it didn't matter much if it was checked or not. The global setting is for referenced viewports. Am I missing something? What are the key factors for fast updating of referenced files bedisdes the file size? Thanks!
We had a similar issue a while ago. We also couldn't find a solution.
2021 Architecture Wishlist
elepp replied to Tom Klaber's question in Wishlist - Feature and Content Requests
My top 10 in no particular order: - Better Windows/Doors ( In my opinion it should be one tool, becaus they are both openings in Walls/Roofs) - Better technical openings, spanning multiple stories and elements - Better Beam/Column tool, capable of interacting with walls and slabs - Improved wall intersections - Styles for Viewports (as mentioned by @Tom Klaber - Clash detection in VW for geometry - Massively improved stair tool - Better Facade tool than the existing one - Consistent UI for all tools and commands - Total rework of records and worksheets -
3d Tiling please!
elepp replied to Sander van Lanen's question in Wishlist - Feature and Content Requests
There already exists a similar Marionette network for that. Maybe that could be adjusted for 3D. Haven't tried that yet. -
Vectorworks 2019 SP5 is now available for download - Update 5.3
elepp commented on JuanP's article in Tech Bulletins
Hi, did you try holding the "alt"-key when you click on advanced options? I get some more options that way. -
2020 Teaser Tuesday - VGM Level of Detail - Vectorworks 2020
I keep my excitement on the backburner for now. While I don't doubt the sincererity of the enigineers here. This teaser is really a "teaser". It's not showing how long it takes for the models to load to begin with and how fast the switching happens from 2D-Plan to 3D. That's where we experience a lot of friction. Especially now that we also have data visualisation in the design layer, I am more than suspicious about the promises of improved speed. -
What's peculiar is also, that the nodes inside the object disappear, except the wrappers.
Other Marionette Objects. I have one that is summarising the floor area of apartments and it shows the same strange behavior. And it's super annyoing, that every time I have to change something in the object, it rotates the plan.
Hi Marissa, thanks for the reply. Here is the file. Still can't figure out what's happening. Especially because it happens with other objects too. IssuesRotatingObjectNode.vwx
VW 2018 - "The file save operation failed" when saving to network
elepp replied to sbutler's question in Troubleshooting
Our local support advised us to use smb, because it's the recommended file protocol from VW Inc. With our setup of AFP via Acronis we are basically alone. No one has experience with that. We used to use smb, but it was even more probelmatic than afp. The connection to the server was very unstable. -
We are also not any further with a solution. Happens regularly but not to all users. We also are not using a quota for our users. -
Import IFC Export Settings...
elepp replied to shorter's question in Wishlist - Feature and Content Requests
That would be also useful if you you have a project with multiple buildings in different files. At the moment you have to enter this data multiple times.- 1 reply
- 1
Digital security protocols in an architects practice
elepp replied to Christiaan's topic in General Discussion
Yeah, we are very wary of the Vectorworks Cloud Service. While it provides some nice features, that we test with some unimportant files, we would not use it for our general projects. Being not sure where the information resides and who has jurisdiction over it. (Same goes for Google Drive, Amazon Cloud, Microsoft OneDrive, etc.) Recently there was a discussion here in Germany, that we need our own cloud services, because even if Microsoft or Amazon are promising to keep the data of german customers on german servers, the CLOUD Act still forces these providers to comply with requests form the american government to release information hosted abroad. And we have no way of knowing if our information was accessed and shared. -
Hi folks, maybe someone can help me out here. I've developed an object node that works fine so far in it self. The problem starts when I am working in a rotate plan. Changing the rotation of my object changes the rotation of my plan. Maybe I am approaching this all wrong! Thnx!
Window and Door Tool maturity
elepp replied to Christiaan's question in Wishlist - Feature and Content Requests
I did. And I wish I could upvote it multiple times. So fed up with the current tool. 😭 -
Alternatively you could create a single worksheet for each apartment with a modified search criteria to only get the area without the individual rooms. Downside is that you have to create a lot of worksheets though.
We also encounter this problem regularly. The only soultion I found so far is to change the criteria manually in the formula bar. It's also the only way to change an "&" criteria into a "|" citeria, or vice versa. Very annoying. With more and more focus on the "I" in BIM, we need to have more flexable and userfriendly ways of sorting and searching our necessary information. My colleagues always look with befuddlement at me when I am explaining theses things.
Vertical text wrapping in worksheets
elepp posted a question in Wishlist - Feature and Content Requests
Hi, we would like the possibility to wrap a text in a vertical orientation inside a worksheet. To achieve a pleasing appearance of our worksheets, we sometimes rotate the text for the headers vertically. At the moment though it's not possible to have that text wrapped. The header row can become quite long in these cases. Thanks! -
Your voice in this forum will be dearly missed! All the best for your next part in life! May the force be with you 😉
Does this work with afp as well, especially when used with acronis files connect? I am no server admin, so my knowledge of these things is a bit shallow 😄 -
Hi, we have this setup in our office. We changed to it due to problems with smb. But since a while we are facing the same problem as described above. People want to save their file on the server and get a message that the drive is full and cannot be saved there. The culprit is not quite clear, but what happens is that somehow the .lck-files get deleted even when the file is actively open. 😣 -
Ah ok! Thanks for clarification. The Problem is that "Name" is the wrong criteria for wall styles. They only apply to object names (screenshot 1). Walls usually don't have that. But in the criteria dialog also offers to look specifically for wall styles. The dialog only offers to choose a wall style from a list, but there is a way around that. After you close the dialog, the used formula appears in the worksheet. (screenshot 2) Now you can edit it directly here. Just write the wall style name that you want to exclude from the search like this (WST<>'CW_*'). This should probably work.
