12 -
Reputation
0 NeutralPersonal Information
Location
United Kingdom
Recent Profile Visitors
Thanks Scott, See below HangingPositionWorksheets.vwx
Ah yes. However, doesn't resolve the issue of the worksheet only seeing one fixture in that hanging position.
By only adding the position to one fixture in the User field, the worksheet will then only show that one fixture and not the rest of the fixtures that actaully have that position. Column A is looking at User Field 1
Thanks Pat, I shall give this a try!
Hi, I am looking to create a worksheet that shows what fixtures are in each lighting position. I would like the position to be shown once and then show the fixtures below. I have managed to get the worksheet set up like this: But really need something like this. Any help would be appreciated
GL Importing all Classes in Resource Libary
JamesB1 replied to JamesB1's question in Troubleshooting
Yeah, I guess I will just re-create them in a new file and just use that as a GL resource file. Thanks @Tom W.- 4 replies
- graphic legend
- class
(and 2 more)
Tagged with:
Would a solution be to temperarly have all GL kept in a seperate Vectorworks file with one class definition for the GL and use that a resource file for all GL Styles?- 4 replies
- graphic legend
- class
(and 2 more)
Tagged with:
I have a resource libary that is used across the business and recently we have been starting to use Graphic Legends (GL). When we import the GL into the required document all class definitions from the resource liabary then get imported into the new document. Is there a way to make sure either no classes are imported or only the class definition of the GL is imported?
- 4 replies
- graphic legend
- class
(and 2 more)
Tagged with:
I have solved half of this issue. The font weight appearing slimmer was down to the font being a variable font and not a static font. However, I am still experiencing the issue of parts of the font appearing missing when zoomed out but not when you zoom in.
- 8 replies
- export
- sheetlayer
(and 3 more)
Tagged with:
Unfortunetly not, This particular sheet has no transparent layers or classes. But not only that, i am struggling to understand why the title block symbol that makes up the cover page is changing so much. I can't seem to understand why the font changes so much between the Vectorworks software, PDF and JPEG.
- 8 replies
- export
- sheetlayer
(and 3 more)
Tagged with:
This is set to 300DPI but i tried this morning with it at 2500DPI. Issue doesn't seem to go. I don't usually use rasterize PDF. This is what my export options are normally:
- 8 replies
- export
- sheetlayer
(and 3 more)
Tagged with:
JamesB1 changed their profile photo
Hi, I have been having trouble getting sheet layers to export as shown in the Vectorworks Software. When Exporting as a PDF the fonts seem to be patchy and in both a JPEG and PDF export the drawings seem to be grey looking. This is what the sheet layer looks like on the software: This is what it looks like as a PDF: This is what it looks like as a JPEG: I have made sure that my DPI is 300 and every export is at the maximum quality. Any help would be appriciated
- 8 replies
- export
- sheetlayer
(and 3 more)
Tagged with:
