2,939 -
Posts posted by Bruce Kieffer
Fixed in VW 2025 Update 2.
Thanks @michaelk and @Pat Stanford for the workaround suggestions.
4 minutes ago, bcd said:
I like the direction you're thinking
@Bruce Kieffer
And it it extends to other Criteria too. Say we're cleaning up the file structure, renaming Classes, Layers, etc. fixing typos... It would be helpful and intuitive if VW were to ask 'do you want to use new names in existing Worksheets?'&/or when next recalculating the Worksheet a dialogue could suggest 'your previously wonderful worksheet now appears to be broken - do you want help fixing it by substituting broken criteria with the new names' Yes, this would require a new Worksheet Manager tool but that would have wide ranging benefits and expansion possibilities.
My feelings exactly.
I have a worksheet that counts symbols by symbol name. If I change a symbol's name in the RM, then my worksheet losses that symbol's reference, and I have to edit the worksheet's criteria and reassociate the symbol's to its revised name. Is there a way to update the worksheet to recognize the symbols revised name?
OK, I'll move on. Thanks. Sad!
No go on the refresh.
No go with renaming the user folder. Vectorworks really did not like that. It wanted my serial #. OK. I added it, then Vectorworks said I had reached my limit.
Yes I am using .sta files, in fact I made a few new templates from the file menu and none of those show on the Home screen either.
I'm going to give up on this and I will just open templates using file/new use template.
I checked and I have all set up correctly. I even added a Workgroup folder and placed a template in that. I restarted Vectorworks a few times, and restarted my Mac, but still nothing shows in the Home Templates tab.
This is a problem with Mac OS Sequoia and Vectorworks 2025. I can now reproduce the problem. If I right click an object and hold the mouse button down and go to a command, then the command does not work. If I right click an object and release the mouse button down and go to a command, then the command works. Another user confirm they see this same behavior.
More testing is making me wonder if this is a conflict with Keyboard Maestro. There's something definitely strange going on. If I long pause on a Vectorworks 2025 contextual menu item, click it, then it works, and then all the context menu commands work after the first one does. Keyboard Maestro running or not. I hate troubleshooting!
I found the problem. It's a conflict with Keyboard Maestro. I don't have this problem with Vectorworks 2024, or any other app. I let support know I found the conflict. Hopefully they will fix it soon.
1
7 hours ago, Stephan Moenninghoff said:
Are you running antivirus software? This sounds like something is blocking parts of Vectorworks.
No, but I did think about booting in Safe Mode. And I have a few other things to try this morning before I call support again.
On 9/23/2024 at 12:19 PM, Tom W. said:
It works for me. Are you sure you're right-clicking in empty space + invoking the Doc Context menu...?
Nope. No fix. Sad. Now what?
I found out today that none of my contextual menu commands are working. I'm reinstalling Vectorworks now. I sure hope that fixes this problem.
I will call support tomorrow.
Yep. It does not work for me.
2 hours ago, Tom W. said:
Try adding it to the Document Context menu instead.
I tried that too and it still does not work.
9 minutes ago, Pat Stanford said:
That would be a script. I won't have time to think about this for at least a couple of weeks. Hopefully someone else chimes in sooner.
Thanks Pat, don't do work on it. I don't have much need for that functionality beyond last night. I was just wondering if was built into Vectorworks and I did not know.
Each palette has its own search field, and Quick Search only searches Tools and Menus or both simultaneously. I want to simultaneously search the layers, sheet layer, viewports, and saved views palettes.
Multi-pane Saved Views.
Posted
Nice, but I want Vectorworks to remember the multi-pane setup and the views in each pane.
