This is a good question. I think the last time I looked into this I created a flatfish (invisible Truss Symbol).
So I could use 'Change Trim Height Of System'
It's not the best solution but it works.
I am taking about choosing between Auto plane or Layer plane.
" (Front Elevation POV),"
If Mike is drawing in a front view for the first time its likely that he still has layer plane toggled.
The only way to do this would be to remove the fill from the other 2d components that you don't want Data vis to fill and leave the fill of the objects that you want coloured.
And then set Data Vis to apply a fill.
it does not apply fill to classes.
Hi Chris, it does not shorten the list only what objects get selected.
We are working on Data Vis, there is an existing enhancement request to update the list using criteria.
All the best
Tom W
"You can also pick individual colors in the DV dialog, and then export that as a palette to make it easier to reuse your chosen colors in a future DV scheme."
Thanks Rick, was not aware of that.
In terms of a long list of symbols I also add additional criteria such as class and/or Record Format is present or even 'Field Value' is. Or even Symbol name 'Contains'.
Providing you have setup your file and workflow diligently then extra criteria can be applied which can help you filter further.
Because Pink is close to Red it goes through the spectrum of all of the other colours in between. Red and Green are too close together to be discernible.
Hi Wood,
Autocolour can choose from a manufacturer pallet for a start and end colour. If there is not much difference between the colours try choosing colours that are further apart on the colour spectrum.
Below are three screenshots notice the start and end colours and the different results.
Do you have the MA VizKey? I don't think you need it for sACN but am not 100%.
If Vision can see it, then it should respond.
So long as the input is set to sACN.
Hi @jgulbrandsen
I was unsuccessful as the the hanging position is a 'container' object and cannot write data to the objects within it.
I have feature requested this and its on the list!
You can create and edit custom 2d components for front views, this can take awhile.
You could always just apply a data visualisation to the front viewport to colour code by fixture type.
