TKA
243 -
Everything posted by TKA
wait a minute, there is no orchestra and singing praises for the new release, just a silent spy like appearance???
if you erase old crop then it will let you do a new one the way you want
may be if you just let the cursor hover above the object it may appear selected but it isn't, that actually happens to me when working fast
highlight the object, in the info box click on render tab (on the right) then in the middle of the info box there will be rotation scale
for some reason, additionally, I need to select next box below : "preserve...." too make it happen
Sorry, what I meant was "publish" to match the stacking order, sheet numbers have different prefixes which change the stacking order to alphabetical. I have a set where a need to change sheet numbers and names as I develop it (need to print progress sets) and every time I need to essentially start from scratch, over 120 pages and suddenly its a lot of work, almost easier to just save it as pdf and just drag pages around in pdf reader.
I was wondering why by default publish box organizes sheets alphabetically by name as opposed to sheet number which is presumably what everybody does, am I missing some hidden option to set "publish" by sheet number?
Imported image background not transparent
TKA replied to Ned Daugherty's topic in General Discussion
I bring them as pdf via copy (from preview, paste from clipboard and drop solid background in attributes, that works on Mac, don't know about windows -
sane set up, I am getting beach balls when selecting drawing label in annotations, also anytime I touch some of the parametric objects like table with chairs getting it to, sometimes I return to viewport and info box is still showing table as seated object. But its not consistent, still trying to figure out what causes it.
I am trying to do a simple thing: have space tool elements different attributes via classes. Class assignment is working fine, however, it seems like pen and fill cannot have different attributes, namely, I am trying to have fill @ 5% and label @ 100% opacity - space sits on top of everything else with label being 100% sharp and area fill color coded but showing furniture etc behind. Is it just me or is the label tool working that way.
- 1 reply
- space tool
- graphic
(and 1 more)
Tagged with:
so I managed to get it done with legacy custom stair tool. I think there should be a check box "override stair tool logic"
I have been trying to configure rather simple stair. In 2018 it nearly impossible, but in 2019 I am getting close. My main issue is that I am getting error messages (two treads are partially melted..., etc) that doesn't explain what is wrong and it does not make sense geometrically. So I am wondering if anybody knows which settings are causing this. Also, I arrived at this configuration by trial and error changing different values till I almost got what I wanted. Also, it is not possible to have nosing in this stair, I unlocked overall stair dim . Attached is line drawing of the stair and above is VW stair which has one offset set at 2" and it cannot get smaller.
there is a line type edit in resources, is there a way to edit line thickness in a similar way to removing classes: remove unwanted thicknesses and make them conform to whatever new standards I want. I know I can do it by custom selection tool but its time consuming and not as instant as removing classes.
I think these are lights and cameras, go to light and views palette and make them invisible
the stair tool doesn't allow for stair that is composed of two raisers and one tread, is this right??? or is there a trick?
I have been using small intuos Touch (very useful for scrolling and zooming), and various versions of Wacom tablet before Intuos. Small works fine for me, and yes its just the right size relative to the natural movement of hand, similar to small sketching writing.
Boh, you are right, I have misunderstood your question, may be if you . What I understood is that let's say you have 6 layers and 3 different types of seating spread across all layers. You want to have box in a spreadsheet showing just type 1 seating on layers 1,2,3, that will be scenario where both chair type and layer will have to be present in order to register in the box. But I suspect you might have something else in mind.
Is there a way to round off dimensions in a worksheet?
TKA replied to Cris with no H's topic in General Discussion
select whatever cells you want then go to format cell and under "number" you can force it to no fractions -
I am saving palette position and yet every time I start VW the top plate gets squished, and every time its different, just wondering if any body has an idea why this is happening. I am enclosing saved position and then 2 examples after quitting VW
thanks for the info about Sierra, I have been using Mac minis in my office for years now, one I have now is from 2012 and works fine for me, however, I wouldn't mind speeding up rendering times. I use it as a portable device: I have screens in my office and at home and I bring my mini with me hence my questions about it. But I see the point about graphics, usually it is the most limiting part which rendered all my old iMacs unusable at certain point.
so the new Mac Mini has been released, I have been waiting for this quite a while, obviously it will come with Mojave. Is there a timeline for VW to be compatible with the new OS. Alternatively, has anyone (I know nobody has an answer to that today) successfully downgraded new Mac mini to High Sierra?
