Francois Levy
    344
Reputation
98 Excellent
4 Followers
Personal Information
  • Occupation
    Architect
  • Homepage
    www.francoislevy.com
  • Hobbies
    Architecture, BIM, aerospace
  • Location
    United States
Recent Profile Visitors
  1. That’s odd. My new files use the new icon
  2. I just have a Vectorworks file with the icon drawn as I like it. Select (including the 0 line weight bounding rectangle for proper sizing in the Dock), copy, and paste in the Get Info box (Mac). Done. VW icon v2025.vwx
  3. [I've deleted this post]
  4. When I tap a PDF in Nomad it opens without the prompt to measure or annotate, it only allows me to measure. I've tried both PDFs that I produced on my desktop and copied to my Vectorworks Cloud folder as well as those I've generated in Nomad from Vectorworks Cloud VWX files. I'm on an iPhone; is that the problem? Nomad v14, iOS 18.5, iPhone 14
  5. You’re welcome.Also, as I posted elsewhere, I recently discovered that there is a PAT file importer available under third-party plug-ins.
  6. It's now possible to import PAT files directly. Go to the Help menu, and select "Download Partner Products...". In the search field, find PAT. Click install, and restart Vectorworks. An PAT Import command will be under Tools/Partner Products. Thank you @ashot for pointing this out!
  7. It's now possible to import PAT files directly. Go to the Help menu, and select "Download Partner Products...". In the search field, find PAT. Click install, and restart Vectorworks. An PAT Import command will be under Tools/Partner Products. Thank you @ashot for pointing this out!
  8. It's now possible to import PAT files directly. Go to the Help menu, and select "Download Partner Products...". In the search field, find PAT. Click install, and restart Vectorworks. An PAT Import command will be under Tools/Partner Products. Thank you @ashot for pointing this out!
  9. Attached are some hatches I've collected over the years, as well as a couple of files contributed by Ashot. AVWC_Hatches.zip
  10. Jeff, I don't use Rhino, and I'm not going to introduce it into my workflow for one project (I'm an architect, not a land designer; this is a one-off where getting a proper survey is proving difficult). Kevin, yeah, in fact there were Shapefiles I was able to dig up, but unfortunately all contours are 2D and have no Z data.
  11. I see that DEM import hasn't been discussed here in _10 years_ Is it currently possible to import DEM datasets into Vectorworks? I’ve downloaded some LIDAR datasets from a municipality, and it’s showing up as a folder with numerous XML, RDD, and IMG files.
