Change your layer options to Show/Snap/Modify others if you want to edit objects on other layers.
your class setting should always be Show/Snap/Modify others
This movie might help, at the 9:21 mark https://youtu.be/DpRRe79rrdM
and this one https://youtu.be/L_kdMBcxL1s
and this one https://youtu.be/84ukOjJgPjI?t=913
Vectorworks will switch to a working plan if you use a 3D object. So, if you click on a 3D tool, you will get the change. If you work mainly in 2D, use the "0" key on the numeric keypad, or CTRL+5 (command+5) to change to Top/Plan
my understanding is that copy and pasting groups of viewports from one file to another was a technique that some of us used, but caused trouble in the file. I thought that this had been prevented in VW 2022.
You used to be able to resize a viewport by grouping it and strecthing it. I couldn't do this in VW 2022 last time i tried.
If you make a symbol from the plug-in doors, you can add the text to record. If you use a symbol, you can add the record inside the symbol so that as you place the symbols drawing, it automatically adds the record.
Michael’s idea should still be used, you will find the data tags much more flexible.
In this movie, I show you how to draw a quick building using Vectorworks walls, slab, foundations, roof, and roof framing. The techniques I use on this simple building can easily be used on a more complex building.
there are two ways to do this. You can use roof faces, or you can use the roof tool and cut out the bits you don't want.
here is a movie on roof faces:
