Sharon F Posted April 28, 2022 Share Posted April 28, 2022 I would like to create an excel spreadsheet that has a plant list with images - specifically the "plant image form" - from the plant data base. all I get is - =IMAGE. I do not want the graphic symbol for the plant - I want the actual picture of the plant. I have spent hours googling and looking in VW help, nothing works. Can someone confirm that this is not actually possible and perhaps I am just wasting my time? This function is available for Dynascape users. Quote Link to comment
Pat Stanford Posted April 28, 2022 Share Posted April 28, 2022 Is the name of the image file located in a field in the object info palette? If so I have something that might work. Quote Link to comment
Jeff Prince Posted April 28, 2022 Share Posted April 28, 2022 7 hours ago, Sharon F said: I would like to create an excel spreadsheet that has a plant list with images - specifically the "plant image form" - from the plant data base. I don't think you are going to be able to do that easily from within Vectorworks to Excel. The plant's form image resides within the Filemaker database. You could create a worksheet within Vectorworks and display the image that way, which would be my preferred method. Several versions ago, Vectorworks was even advertising the capability to add images to plant tags. @Peter Neufeld has some solid advice in this thread which should show you everything you need to know: Quote Link to comment
Sharon F Posted May 4, 2022 Author Share Posted May 4, 2022 (edited) Thanks Jeff - after some searching I found his post, followed his instructions, didn't work, then searched help, went through steps, didn't work. So I imported his spreadsheet - and Voila! it works! must be a missing link somewhere... Well at least it partly works. Now I have 50% of the right images to the right plants, the other images - are from other plants. Yew has a picture of a rose of Sharon, Annabelle hydrangea is a bully and has taken over other plant images. They are correct in the plant data base. But some work. 🙂 Edited May 4, 2022 by Sharon F 1 Quote Link to comment
Sharon F Posted May 4, 2022 Author Share Posted May 4, 2022 On 4/28/2022 at 5:58 PM, Pat Stanford said: Is the name of the image file located in a field in the object info palette? If so I have something that might work. Yes - it's in Object info -Tag Display - set custom tag - then "select image form" - which corresponds to first image in plant database. VW 2028 Landmark, forgot to enter that. Also see my response to Jeff about wrong images attached to plants. Quote Link to comment
Pat Stanford Posted May 4, 2022 Share Posted May 4, 2022 My work around is not going to work. Sorry. =PlantImage(X) where X is 1 to 4 depending on which image you want is the best way I know of. Quote Link to comment
Sharon F Posted May 4, 2022 Author Share Posted May 4, 2022 Thanks. I'm now getting an error code 1 when trying to update the database - VW tells me to look it up in Google, can't find a specific answer so packing it in for today. Quote Link to comment
