fuberator Posted December 15, 2021 Share Posted December 15, 2021 I have a total number of sheets in my titleblock layout. For some reason it remains zero, even if I have a bunch of sheet layers. The Sheet Data.Sheet Number works fine. Not sure when it started happening, it was not always so. Here is an example in a document with 5 sheet layers. Thanks for any advice Quote Link to comment
0 markdd Posted December 15, 2021 Share Posted December 15, 2021 (edited) Have the Title Blocks been set to Active? Edited December 15, 2021 by markdd Quote Link to comment
0 fuberator Posted December 15, 2021 Author Share Posted December 15, 2021 Hi Yes they are active. All the other linked values work fine. thanks Quote Link to comment
0 Vectorworks, Inc Employee Nikolay Zhelyazkov Posted December 15, 2021 Vectorworks, Inc Employee Share Posted December 15, 2021 Hello @fuberator, Could you please attach a sample test file showing the issue or PM me a test file if you do not want to share it here, so that I can check what is going on? Thanks, Nikolay Zhelyazkov Quote Link to comment
0 fuberator Posted December 15, 2021 Author Share Posted December 15, 2021 6 hours ago, Nikolay Zhelyazkov said: Hello @fuberator, Could you please attach a sample test file showing the issue or PM me a test file if you do not want to share it here, so that I can check what is going on? Thanks, Nikolay Zhelyazkov Hi. PM incoming thank you Quote Link to comment
0 Vectorworks, Inc Employee Nikolay Zhelyazkov Posted December 16, 2021 Vectorworks, Inc Employee Share Posted December 16, 2021 Thanks for the file! 🙂 The problem was that "Use total number of active title block borders" was not selected in Project Data, causing the Total Number of Sheets to be not automatically calculated but manually inputted. Selecting this option fixes the problem. 1 Quote Link to comment
fuberator
5 answers to this question
