jnr Posted February 21, 2005 Share Posted February 21, 2005 So now that the common layer does not script with a document setup (a-la V10), how does one get information that has to appear on each sheet in the same place (i.e. title block, copyright notice, etc.)? Copying the same thing (be it text or symbol) 41 times for a 41 sheet set is not an option. Ideas? Quote Link to comment
Kevin Posted February 21, 2005 Share Posted February 21, 2005 As far as I know, yes, that is the way it is now done. I have a title block symbol now. I paste it on each of the sheet layers. Quote Link to comment
Jonathan Pickup Posted February 21, 2005 Share Posted February 21, 2005 why is the symbol not an option? if you use a symbol, you can use the issue manager to fill in the title block and control the issue of drawings and revisions... Quote Link to comment
jnr Posted February 21, 2005 Author Share Posted February 21, 2005 Jonathan: Because I would have to manage 41 instances of the symbol and not one symbol on one layer (the old way). This is also a case of old dog-new tricks. If I can script a common layer at document setup and not have to manual add a common layer to each sheet, I could live with that. thanks Quote Link to comment
Travis Posted February 21, 2005 Share Posted February 21, 2005 jnr, If your title block is like mine, you have both static (company logo, address, etc.) and variable information (project name, sheet title, etc.). You must be placing something on each sheet that shows the variable information (which is probably a symbol or PIO that's in turn connected to the Issue Manager). Jonathan's point is simply to expand whatever you're placing 41 times to include the static information. Draw it once, store it as a symbol that contains both the static and variable info, and then place it like you're probably already doing. It's really only one symbol to manage--Issue Manager takes care of the variable details for you. Good luck, Quote Link to comment
Jonathan Pickup Posted February 21, 2005 Share Posted February 21, 2005 issue manager will take care of the static and the variable information and it will allow you to put different issue notes for each issue, something that your current method won't do Quote Link to comment
Kevin Posted February 22, 2005 Share Posted February 22, 2005 With issue manager, are we constrained to using the VW title block templates? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted February 22, 2005 Vectorworks, Inc Employee Share Posted February 22, 2005 You can use any symbol, but it has to meet some requirements (symbol name, location, record attached etc.) The easist way is to modify the symbol template that is provided. This is covered in the manual. Quote Link to comment
