Feature request or maybe somebody has a good workflow. Hopefully my parenthesis will emphasis what I'm trying to get across...
- I'm working on a drawing "zoomed out"
- I need to "zoom in" on a specific item to do something...edit some geometry, add a locus, add an alignment marker, move an object, etc.
- I need to "zoom back out" to where I was before to continue what I was doing.
My idea is maybe a new undo command that ONLY works on view changes (I know you can do the opposite...group view changes into a single undo). And then map this to a hot-key or mouse button
...or maybe a bit of volatile memory that always logs "drastic" view changes
...or a function that always updates a saved view (x, y, zoom, render, standard view, etc) every # seconds, with a command to recall it
Undo won't work because I'd undo the work I did while "zoomed in"
Currently, saved views would work, but you have to remember to save a location before you changed views.
The loupe tool kinda (z) works, but you can't really edit anything while zoomed in.
livespace josha
Thoughts?
6 answers to this question
