TaraC Posted June 29, 2021 Share Posted June 29, 2021 I am trying to use the Existing Tree Tool and I want to turn off the tag. I've read in other Vectorworks forums that I can "get plant data" to select a species and "set the tag class" of the existing tree to turn it off. By in the object info palette that I have in Vectorworks 2021, there is no "get plant data" option under the existing tree tool and there is no tag class option. I am using landmark 2021. Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted June 29, 2021 Vectorworks, Inc Employee Share Posted June 29, 2021 The Get Plant Data button is in the Plant Tool, not the Existing Tree tool. The Existing Tree tool has a Get Species Data button on the Object Info palette. You'll find the place to set the class and tag options under Tag and Number Options. Quote Link to comment
jwlandscape Posted July 1, 2021 Share Posted July 1, 2021 Hi Tamsin- Is there any way to create a default location of the tag on the existing tree? I'd like to just have the tag in the centre with no leader line but can't figure out how to set it as a default. Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted July 1, 2021 Vectorworks, Inc Employee Share Posted July 1, 2021 No, I don't believe so, but for all tagging, I would recommend you look at the Data Tag tool instead of looking at the tagging options within the individual tools. With Data Tags, you can include whatever information you want, control the layout yourself and tag multiple objects in one click. Here's a course in the University that will teach you about Data Tags. Don't be put off by the title - Data Tags are not just for hardscapes. They are for anything that has data attached:https://university.vectorworks.net/mod/scorm/player.php?a=85¤torg=articulate_rise&scoid=170 I will also make a small example file and attach it here. Quote Link to comment
Vectorworks, Inc Employee Popular Post Tamsin Slatter Posted July 1, 2021 Vectorworks, Inc Employee Popular Post Share Posted July 1, 2021 Existing Tree Data Tag Example.vwx In this example, there are two trees, which are autonumbered. The tag is in a class which is invisible. I have then created a Data Tag which looks at the Existing Tree parameters, and displays the tree number with the Botanical Name field. WIthin its style, I have defined that it will always be centred on the Existing Tree. 5 Quote Link to comment
jwlandscape Posted July 2, 2021 Share Posted July 2, 2021 Thank you for this. I think this is the direction I need to go. Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted July 2, 2021 Vectorworks, Inc Employee Share Posted July 2, 2021 You're very welcome. Warning - Data Tags are addictive... they are SOOO useful! Quote Link to comment
hollister design Studio Posted July 15, 2021 Share Posted July 15, 2021 Tamsin - another Existing Tree tool Question. I like using the 'use 2D component symbols" (ET05 and ET06 work well with our style) but it seems that the geometry is on the 'None' class. This makes selecting existing trees awkward (they only highlight at the very center of the object) and all but negates the 'class options:' usefulness as, for example, if you have your existing tree class active and set to "grey other" it greys your trees as the '2D component' geo is on 'none' by default. So my question: How do we set the '2D component' geometry class to a custom class as opposed to 'none? On 7/2/2021 at 2:56 AM, Tamsin Slatter said: ... Warning - Data Tags are addictive... . This is so true! Quote Link to comment
Shane W Posted August 26, 2021 Share Posted August 26, 2021 Hi, I was wondering what the best approach is when you are working in large areas and have existing forest patches you want to include in the design. The landscape area tool seems like it could work perhaps, but are there implications for taking this approach? I'm usually working on larger properties (50-160 Ha) and they have areas of exotic and native forest that are to be retained, but I don't want to waste time going through and adding individual trees or defining specific species mixes for these. Appreciate your guidance. Cheers! Shane Quote Link to comment
Shane W Posted November 9, 2021 Share Posted November 9, 2021 On 8/26/2021 at 3:54 PM, ActionEcologist said: Hi, I was wondering what the best approach is when you are working in large areas and have existing forest patches you want to include in the design. The landscape area tool seems like it could work perhaps, but are there implications for taking this approach? I'm usually working on larger properties (50-160 Ha) and they have areas of exotic and native forest that are to be retained, but I don't want to waste time going through and adding individual trees or defining specific species mixes for these. Appreciate your guidance. Cheers! Shane UPDATE: I have tried using the landscape area tool, but it seems to only be useable with the 3D style set to a solid. Image props (at that scale) makes VW grind to a halt. I'd be interested to know if anyone else has a different approach. 1 Quote Link to comment
Tom W. Posted November 10, 2021 Share Posted November 10, 2021 I don't know if these threads are any use: 2 Quote Link to comment
pippa1 Posted January 31, 2023 Share Posted January 31, 2023 Trying to use the Existing Tree tool for multiple trees, and a single tag to identify the groups of similar trees. Any suggestions? Cannot insert multiples of existing trees Quote Link to comment
