Christine Mulinder Posted March 18, 2021 Share Posted March 18, 2021 Every time I add extra leader lines on the call out tool Vectorworks 2021 crashes out. Anyone else had this? Quote Link to comment
0 MSLD Posted March 18, 2021 Share Posted March 18, 2021 I had similar problems, when I deleted an extra leader line it would crash. Tech suggested I run the update/ repair ( open the Vectorworks Updater app in your Vectorworks 2021 folder and click on the advanced options and then click repair.) and that seemed to fix the problem Quote Link to comment
0 SFS Chris Posted April 29, 2021 Share Posted April 29, 2021 I can add leaders but the extra ones will not delete. VW does not crash, tho'. My version is up to date. Does the Updater work differently? Thanks! Quote Link to comment
0 RGyori Posted April 30, 2021 Share Posted April 30, 2021 On 3/18/2021 at 10:51 AM, MSLD said: I had similar problems, when I deleted an extra leader line it would crash. Tech suggested I run the update/ repair ( open the Vectorworks Updater app in your Vectorworks 2021 folder and click on the advanced options and then click repair.) and that seemed to fix the problem Hi @SFS Chris , if you do exactly as described above you are not reinstalling Vectorworks but repairing it. I've done this at times and the repair process has upon occasion found some problem and repaired it. Certainly worth the try. Quote Link to comment
0 SFS Chris Posted April 30, 2021 Share Posted April 30, 2021 Thanks, Robert. I tried your suggestion. It didn't work. The behavior is unchanged. I have sent in a bug report on it. 1 Quote Link to comment
Christine Mulinder
4 answers to this question
