Christian Fekete 17 Posted October 5, 2020 This is not working, please fix or advise. Thanks Quote Share this post Link to post
0 markdd 695 Posted October 5, 2020 It works perfectly for me. Are you sure that you have Use at Creation set in the Edit Classes dialog.... If you don't want to use this function, then make sure you have the attribute palette set to Make all attributes by class. Quote Share this post Link to post
0 Christian Fekete 17 Posted October 5, 2020 1 minute ago, markdd said: It works perfectly for me. Are you sure that you have Use at Creation set in the Edit Classes dialog.... If you don't want to use this function, then make sure you have the attribute palette set to Make all attributes by class. I use the OIP to change that but it does not work 🤭 Quote Share this post Link to post
0 markdd 695 Posted October 5, 2020 What object are you using? If you select the object and then in the Attributes palette use the Set all attributes by class menu item at the bottom of the palette. Quote Share this post Link to post
0 CipesDesign 148 Posted October 5, 2020 *Sometimes* I have found instances where VW's needs to be *forced* to comply. To do this I choose "remove class attributes" then choose "attributes by class". Also, I believe this drop down menu is in Attributes Palette (as opposed to OIP). 2 Quote Share this post Link to post
