islandmon Posted January 17, 2006 Share Posted January 17, 2006 pat, There are basically 2 options: 1) Create a 3D rock and map a texture to it. 2) Create an Image Prop and map an image of rock(s) to it. In order to make a convincing 3D rock model a few hundred polygons are required to form the 3d mesh surface. An Image Prop is simply a pic of one or more rocks. The Prop can be set to Cross-Planes giving a 3d look and shadows. Quote Link to comment
td4stage Posted January 18, 2006 Author Share Posted January 18, 2006 I am wondering if anybody could point me in the direction of a tutorial on how to model large rocks. Or, if anybody has a rock model or two to share, that would be cool as well! thanks in advance! Quote Link to comment
Michelle Posted January 21, 2006 Share Posted January 21, 2006 I wish there was a place online to buy this sort of stuff. If I had one I'd give it to you. good luck Quote Link to comment
Travis Posted January 21, 2006 Share Posted January 21, 2006 Patrick, If you'd like to PM me with your email address, we've got a couple of boulder symbols we'd share with you. Quote Link to comment
propstuff Posted January 21, 2006 Share Posted January 21, 2006 I had a go at lofting 4 or 5 irregular freehand NURBS curves (with a 3D locus at the top to cap it off) to make a surface. It doesn't have the gnarly surface that would be possible with a detailed mesh that EJ suggested, but with a highly irregular image based texture applied it didn't look too bad. Should be easily good enough for a set model. Also, it only took about 5 minutes of tests and re-runs to make and texture. it added about 600Kb to an existing model. HTH, N. Quote Link to comment
