Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
PeterYip
Strange binding on render
I recently did a drawing, there seems to be some stranger binding / pattern on OpenGL render.
setting:
Background Render: OpenGL
RW Background: HDRI White
Foreground Render: Hidden Line
I have tried it with different texture but getting the same result, was wondering if anyone has any idea what might cause this?
Not sure but my first though is to rule out z-fighting where 2 surfaces are coincident.
Check that you haven't duplicated your set.
The model is centre from internal origin, and there are no duplicated set, its a single solid addition.
This is probably the first time I came across this... might play around a little more and see if I could get to the bottom of this.
It may be that the foreground hidden line render is showing a surface hatch. Try turning off surface hatches in foreground render preferences.
Tried that without any luck, however I think I have solved the issue.
Turns out if I change the crease angle to 0 on OpenGL options at background render setting, that goes away !!!
Thanks a lot for all the helps.
I'm glad you found a fix but that doesn't sound like it's the root cause of the issue.
What is the Background Render>OpenGL>Detail set to?
@PeterYip
Are you sure that the Draw Edges option of the OpenGL settings are not contributing to your problem?
@markdd Since the issue goes away when I set the crease angle to 0, and I have also tried it with Draw Edges switch of and fixes the problem as well.
So its fair to say it is draw edges that are contributing to the issue.
