Christian Fekete Posted April 13, 2018 Share Posted April 13, 2018 Is there a way to create a viewport with a 3D view with a clip cube cutting throught the model. It seems as if the clip cube disappears with the switch of the clip cube being off . In other word, I am not trying to create a section view but a 3D view with clipped parts using the clip cube and keep the viewport setup for the clip cube ON whether or not the general setting for the clip cube is ON or OFF in the design layer later on. Hope that makes sense. Thanks CF Quote Link to comment
Popular Post markdd Posted April 13, 2018 Popular Post Share Posted April 13, 2018 I made this short video about this which I think is what you are after. 5 Quote Link to comment
Boh Posted April 13, 2018 Share Posted April 13, 2018 This is a great video tip! In in the past I have also taken screen shots and pasted the image onto a sheet layer. Can this technique be used for a iclip cube view that clips 2 or more parts of your model? E.g.a view of an internal staiR Quote Link to comment
markdd Posted April 13, 2018 Share Posted April 13, 2018 Is this the kind thing you mean? Quote Link to comment
Christian Fekete Posted April 14, 2018 Author Share Posted April 14, 2018 @markdd mark I can’t seem to make it stick in my viewport, the view has no clip cube in it @markdd Quote Link to comment
markdd Posted April 14, 2018 Share Posted April 14, 2018 Make sure that the viewport that you are referencing is updated. I find this easier from the navigation menu. Any use? Quote Link to comment
Christian Fekete Posted April 14, 2018 Author Share Posted April 14, 2018 @markdd yes I do that and that’s when I realize the clipping disappeared. I will call VW Monday and will let you know how we resolve this. Thank you Quote Link to comment
markdd Posted April 14, 2018 Share Posted April 14, 2018 If you send me the file or post it here then I could take a look for you. Quote Link to comment
Christian Fekete Posted April 14, 2018 Author Share Posted April 14, 2018 @markdd Thanks for the offer, I think its a setup issue and will get with VW on this, no emergency. On the other hand, how do you setup the clip cube, red fil to the hatch you have on your section? Quote Link to comment
markdd Posted April 15, 2018 Share Posted April 15, 2018 When the viewport is created, a Section class is also created. That is where the section plane properties are initially controlled from. All you need to do is to change the properties there. The range of section cuts available to you can also be displayed in the advanced properties of the viewport. Quote Link to comment
Christian Fekete Posted April 15, 2018 Author Share Posted April 15, 2018 got that, will look into it, thank you mark Quote Link to comment
Christian Fekete Posted April 15, 2018 Author Share Posted April 15, 2018 (edited) Ok, I figured what I was doing wrong. Did not follow your video properly, forgot to select the side of the clip cube prior to creating the viewport on the design layer. The other thing I noted is that the section attributes must be setup by class so that it takes the hatch that you want. Got it now. Thanks again for your help. Best CF Edited April 15, 2018 by Christian Fekete Quote Link to comment
ninel Posted September 8, 2021 Share Posted September 8, 2021 Hi, I faced a problem during using clip cube on Vectorworks, I want to make a section in "oblique cabinet 45' "view, but unfortunately all the point cloud turn into black. Moreover, I couldn't export image file from oblique view as well. I will really appreciate if you could help me with this regards. Quote Link to comment
AlanW Posted September 9, 2021 Share Posted September 9, 2021 Hi What you do is set up the view you want in the Design Layer then on screen plane you draw a rectangle around the area you want then create a viewpoint from that. you should get what is attached. HTH Quote Link to comment
