new to the board...forgive me if I'm posting in the wrong thread. This Saved View Issues has plagued me for years. I don't think there is a solution but it hasn't stopped me from asking anyone who will listen.
I have lots of Saved Views pre-made in my temp file. (1. Plan, 2. Section 3. FOH 4. Sidelight, etc.) In those views...I have the screen location and zoom fairly close to probably how I need it and have pre-set class and layers visabilities based on the view. With each new file, as the drawing comes together...I update elements of those saves views as the drawing requires. The problem is that I have many saved views where some of the layers/classes are set to "Ignore" (the red circle with a slash)Ignore" is not an actual state, a class can't sit in an "Ignore" state, it simply means "leave this alone when recalling the view."
Now imagine you turn some of those ignored layers/classes on or off, as if you were in the middle of your workflow, and adjust the zoom/pan, etc. and attempt to "Redefine" the Saved View. You now have a problem. If you uncheck Layer Visibility and/or Class Visibility those parameters will now be completely removed from the Saved View (Active class, etc. becomes greyed out in the visibility settings.) If you leave them checked, the current Class/Layer setting (either on/off/grey) will OVERWRITE any class/layers you had set to be ignored. There is in fact no way to update the Saved View without breaking classes/layers that were set to ignore.
In my opinion, unchecking a parameter in the "Redefine" window should not REMOVE those settings from the Saved View but simply leave them untouched in this current action. My terrible workaround is that I keep a separate list of how I like the visibility settings for layers and classes in various saved views. (because it's too many to remember.) Any time I Redefine a View (mainly to update the zoom/pan) I then I have to go into visibility settings and re-set the settings to how I want them based on my list. It is very annoying and tedious.
Does anyone follow what I'm describing and does anyone have a workaround? help!
Cory Pattak
I have lots of Saved Views pre-made in my temp file. (1. Plan, 2. Section 3. FOH 4. Sidelight, etc.) In those views...I have the screen location and zoom fairly close to probably how I need it and have pre-set class and layers visabilities based on the view. With each new file, as the drawing comes together...I update elements of those saves views as the drawing requires. The problem is that I have many saved views where some of the layers/classes are set to "Ignore" (the red circle with a slash) Ignore" is not an actual state, a class can't sit in an "Ignore" state, it simply means "leave this alone when recalling the view."
thanks.
Cory
7 answers to this question
