Renderworks camera making warped perspective
kufuffin
5 answers to this question
24 minutes ago, Alan Woodwell said:
Click on camera and go fine tune and adjust the perspective angle or select normal perspective.
Yes, I tried normal perspective it doesn't seem to make a difference.
Perspective angle didn't take the warping away, just made it less.
I'd prefer to use orthogonal though.  The problem I have is it doesn't show me the camera view from where I placed the camera, it shows me a view from 100s of feet away from the site model
Edited by kufuffin
You have to keep the camera and target height the same.
This way you will get a 2-point perspective or what is called an architectural camera, so no distortions
of vertical lines.
To finally get your desired clipping (look up), you have to use a viewport with manual border geometry
that you edit and move on your sheet layer.
(Like in reality you will use a special shift lens to adjust the viewing direction while keeping the camer
level)
