Kerschbaumer Posted December 5, 2016 Share Posted December 5, 2016 Searched but yet to find anything - anything out there, either a hatch or tool, that creates the rigid insulation as per the Canadian standard per the attached screen shot? Been long sick of drawing many tiny lines. Thanks in advance 1 Quote Link to comment
markdd Posted December 5, 2016 Share Posted December 5, 2016 (edited) Why not make a linetype? Mark Tiny Lines.vwx Edited December 5, 2016 by markdd Quote Link to comment
Kerschbaumer Posted December 5, 2016 Author Share Posted December 5, 2016 I have no idea how to do that - simply is there a tool or hatch that currently exists? Quote Link to comment
markdd Posted December 5, 2016 Share Posted December 5, 2016 (edited) Just posted an example in the post above.... Ah, you're 2012. I'll try and convert it. It's called a complex linetype. Tiny Lines v2012.vwx Edited December 5, 2016 by markdd Quote Link to comment
Kerschbaumer Posted December 5, 2016 Author Share Posted December 5, 2016 I am v2013, When I open the file all I get is a single white line Quote Link to comment
Kerschbaumer Posted December 5, 2016 Author Share Posted December 5, 2016 Like this screenshot - am I missing something Quote Link to comment
markdd Posted December 5, 2016 Share Posted December 5, 2016 (edited) OK. I have uploaded a 2013 version. You should be able to make a complex linetype of just two short lines which will endlessly repeat themselves. I don't know when these linotypes were introduced so don't know whether they are supported by 2013. If you go to the resource browser though you should find a linetype called "tiny lines". Mark Tiny Lines v2013.vwx Edited December 5, 2016 by markdd Quote Link to comment
michaelk Posted December 5, 2016 Share Posted December 5, 2016 Or a hatch or repetitive unit. Canadian Insulation v2013.vwx Quote Link to comment
Kerschbaumer Posted December 5, 2016 Author Share Posted December 5, 2016 Thanks Markdd - I can now see the offset lines - any suggestions on how to adjust its 'thckness? For eg - I have 2" rigid so that 'line' needs to be 2" thick Also Thanks Michaelk - not familiar with repetitive units - the hatch seems to work but with multiple layers of lines oriented vertical instead of just the 2 I am looking for, which should be fine enough. iam just playing with rotating it for either floor or wall applications Quote Link to comment
markdd Posted December 5, 2016 Share Posted December 5, 2016 Thickness should be controlled by the attributes palette just like any other lines. If you mean change the geometry then you will need to edit that from the resource browser according to what you need. I'm afraid I'm not a Canadian architect so have no idea what is required!! Mark Quote Link to comment
michaelk Posted December 5, 2016 Share Posted December 5, 2016 8 minutes ago, Kerschbaumer said: not familiar with repetitive units - the hatch seems to work but with multiple layers of lines oriented vertical instead of just the 2 I am looking for, which should be fine enough. iam just playing with rotating it for either floor or wall applications The repetitive units uses a symbol and lets you control the spacing (pitch) of those symbols. I made a symbol with those two lines and pointed the repetitive unit tool at it. The orientation of the hatch can follow a wall. Not sure if it does any tricks with slabs or floor objects in 2013. But you can use the attribute mapping tool to change the position, orientation, or scale of any instance of the hatch. hth mk Quote Link to comment
Kerschbaumer Posted December 5, 2016 Author Share Posted December 5, 2016 14 minutes ago, markdd said: Thickness should be controlled by the attributes palette just like any other lines. If you mean change the geometry then you will need to edit that from the resource browser according to what you need. I'm afraid I'm not a Canadian architect so have no idea what is required!! Mark Thanks guys - I dont want to take up your day with this and really appreciate your help. These are both a great start and I will play around with it to see if I can get it where I would like. Cheers Mark Quote Link to comment
Tom Klaber Posted December 6, 2016 Share Posted December 6, 2016 I am confused about why you are not just using a rigid insulation hatch. A complex line type could work - but it seems unnecessary. Why not just use the double line polygon tool and fill it with a rigid hatch? Quote Link to comment
Kerschbaumer Posted December 6, 2016 Author Share Posted December 6, 2016 I dont have one. I should say there was one I did find but it looks nothing like what I know as convention. If you or anyone has one or several hatches you want to share that way it is to me the simplest option - just havent found anything - to be clear I want it it to look like the screen shot at the start of the post - if not I will continue to draw by hand. Thanks Quote Link to comment
Tom Klaber Posted December 6, 2016 Share Posted December 6, 2016 Ah - got-it. The US convention is the diamond hatch which I believe is built in. If you need to replicate your graphics exactly, a hatch would be tough because it is not going to scale correctly with increased thickness. Complex line type is not bad stop gap. I suggest around with the hatch creator. What does that convention look like when you have 12" rather than 2"? Can you send me a screenshot? Next time a have a second - I will see if I can make a hatch. I suggest around with the hatch creator. It is terribly frustrating, but you might be able to make it yourself. Quote Link to comment
Kerschbaumer Posted December 6, 2016 Author Share Posted December 6, 2016 Yeah, I figured the thickness may factor into but, but that said I personally never draw foam any thicker than 4". If it goes more than that I will build up 3 sheets to get to 12" for example. I started to try and build a hatch but was taking me forever as I am not strong in that department - faster just to draw it by hand. Attached is a screen shot of how I usually draw it Cheers Quote Link to comment
Tom Klaber Posted December 6, 2016 Share Posted December 6, 2016 I see. It feels doable. Quote Link to comment
michaelk Posted December 6, 2016 Share Posted December 6, 2016 Here's the hatch and repetitive unit scaled correctly. I think you'll be happier with the repetitive unit. hth mk Canadian Insulation 2 v2013.vwx Quote Link to comment
Kerschbaumer Posted December 6, 2016 Author Share Posted December 6, 2016 Wow - awesome thanks! Let me play around with it - how do I expand the repetitive unit to dill a rectangle? Thanks so much Quote Link to comment
michaelk Posted December 6, 2016 Share Posted December 6, 2016 The repetitive unit tool is in the dimensioning tool set. Select the tool and draw the path as though you are using the poly line tool. Once it's inserted into the drawing you can change the object that it repeats (in this case a symbol called Canadian Insulation) or edit the path like any other VW polyline. The symbol has its insertion point at the bottom. The symbol insertion tool will use the default attributes for the path polyline. Set it to no pen if you don't want to see it. hth mk Quote Link to comment
Tom Klaber Posted December 6, 2016 Share Posted December 6, 2016 The issue you may have with the repetitive unit is that if you do not land exactly on the end of a unity you are going to stop short or go long. It might also have issues turning corners, and the units are not flexible. My limited experience with the tool makes me think it will not work in many scenarios. I am curious though to see what Michaelk has come up with. Quote Link to comment
michaelk Posted December 6, 2016 Share Posted December 6, 2016 Tom You're right about corners and repetitive units. But in this case with sections of slab insulation, I don't think it will be much of an issue. If he wan't still using 2013 I'd say that a line type is definitely the way to go. Much easier to insert, cleaner in corners, and more portable from drawing to drawing. Certainly easier than using a hatch, which would need to be remapped or duplicated and rotated to do the same thing with the section of a wall. And will almost certainly need to be remapped even when using it on a slab insulation. mk Quote Link to comment
Tom Klaber Posted December 6, 2016 Share Posted December 6, 2016 I did consider the hatch rotation issue. You are right that would be a pain. Quote Link to comment
Kerschbaumer Posted December 6, 2016 Author Share Posted December 6, 2016 I wondered that too but It does seem to rotate Quote Link to comment
michaelk Posted December 6, 2016 Share Posted December 6, 2016 That works if you rotate it. Not if you first draw a tall, 3" wide rectangle and then apply the hatch. mk Quote Link to comment
