uglycat
Plants Disappearing
Why do my plants disappear when I change a plant grouping of multiple plants to individual plants ? This only happens when my design layer view is rotated.
3 answers to this question
Normally when object disappear it is due to class visibilities. How are you rotating the plan? If you are using a saved view it is possible that there is a class turned off in the view that needs to be on.
Or it could be something total different.
No, its not class visibility. When I create several plant objects and combine them into one plant object so that I can add the tag, I may convert them back to individual plants as I work and adjust my plan. The problem is if I am working in a rotated top/plan view on a design layer with no saved views/viewports, all classes on etc., the plants not only disappear but convert to a polygon somewhere else in the drawing, they are not hard to find but I'm pretty sure this must be a bug. I've been using vectorworks since 1999 and know my around it pretty well. Any suggestions about what I'm doing wrong would be appreciated. I've avoided using the landmark features for years because of these sorts of nagging issues. The plant tags don't work in 2017 if i use Quantity-ID but that's for another post I had previously made.
It's a Bug.
Change Plant Grouping doesn't work in Rotated Top/Plan View.
