uglycat
Content Count
27 -
Community Reputation
10 GoodAbout uglycat
Rank
Greenhorn
Personal Information
Location
SC
Recent Profile Visitors
Can anyone explain why my plant tags look like the attached image? It happens on every project and adds a lot of time having to adjust these tags so they are usable.
Moving from Mac to PC with Vectorworks
uglycat replied to James Hamilton's topic in General Discussion
How about using Acrobat Reader? -
Has anybody else been experiencing this? I use several worksheets in my drawing sets and set criteria based on what I want to show in the worksheet, unfortunately since switching to VW2020 when I try to edit a worksheet or set criteria within it VW 2020 will just shut down. I've tried all the graphics modes and updated my graphics driver and none of that helps. Its not something that happens everytime but once it starts it will keep doing it over and over. Since worksheets are pretty central to all my drawing sets it pretty much makes VW2020 too unreliable to get any work done.
Just add the acronym to the plant symbol. If you don't want to always have it visible just put the acronym on a class you can toggle off/on.
PC users, I found a utility called "classic color panel" by wintools.info. It enables you to change the color settings just like you could prior to windows 8. It works better than trying to use the high contrast settings, just remember to save your current color settings before changing anything as it changes settings in the registry (It will ask). It doesn't seem to have any effect on any other part of windows, only programs that use the ancient windows interface from windows 3.1 see the changes. Its not a theme that required a crack either, working really nice so far, Vectorworks has a couple issues notably the resource manager seems to not adhere to the color changes but otherwise working great, Lots of room to customize. I was hoping for a dark interface with VW2020 but this actually seems to work well until that happens. I had previously posted about using the high contrast setting to do this but that had a lot more limitations than this seems to. I am not associated with the utility in any way.
- 1 reply
- 2
Could this be a duplicate serial number that is already in use on the network causing the laptop Vectorworks to shut down?? Just a thought. I think if it was a graphics issue it wouldn't be so polite by waiting for everything to load but I may be wrong.
Maybe I am misunderstanding the tag question here but why cant you put the plant tag on a class with an assigned text style that fits the requested standard?
Hey Stu, We struggled with this for awhile but its pretty straightforward. Draw a circle, Under the landmark dropdown menu select create plant style from selection, Next a dialog will appear and near the top you willl see a get plant data button, use this to attach the planting record from the built-in database. Right below the get plant data button is a spot to set the plant ID which is the plant label. Hope that helps.
Mike, My solution that has worked for me has been to close Vectorworks, sign out of windows 10 (If you are using windows), sign back in to windows, launch the updater manually. This has worked for three separate updates now. Don't relaunch Vectorworks when you sign back in!! Do the update first. Hope that works for you.
I experienced the same thing, as a temporary work around I found if you cut and paste the image back in the drawing the selection handles are normal.
Is it possible to to use the sketch render mode for a single layer while the other layers remain wireframe?
Jim, I used the updater as you said to repair the installation and it replaced the two missing plugins that were deleted. I also added the Vectorworks folder to the Exclusion list, everything seems ok at the moment. Thanks for your help.
Jim the select similar tool is missing as I had the system remove the suspect files. Is there a way to reinstall those two tools without a full reinstall?
Hi Jim, this was just Windows defender. As soon as I turned it back on I got the message as well as a message from vectorworks that notified me the two files were altered and couldn't be loaded. No history of any virus/Trojan issues.
Ok, Now after updating i get this message :
