jmartinarch Posted February 29, 2016 Share Posted February 29, 2016 I found I had about 100 colors in the current document with most being unused and some duplicates. Purge did not remove unused or duplicates. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 29, 2016 Vectorworks, Inc Employee Share Posted February 29, 2016 If you run the command twice in a row, does it then remove these colors, or does the second Purge command not result in it finding any resources to remove? Quote Link to comment
jmartinarch Posted February 29, 2016 Author Share Posted February 29, 2016 I made some changes to classes (color used) and then ran the command and it removed a few more, but the button "purge unused" is still ...um err... "live", not grayed out that is. Quote Link to comment
Art V Posted March 5, 2016 Share Posted March 5, 2016 I made some changes to classes (color used) and then ran the command and it removed a few more, but the button "purge unused" is still ...um err... "live", not grayed out that is. Are some colours still manually assigned (i.e. not "by class") to objects and/or symbols? If yes then you will not be able to purge that colour. Especially with imported dwg symbols this can be a pain at times. Quote Link to comment
Gaspar Potocnik Posted March 27, 2020 Share Posted March 27, 2020 So I've been trying to get rid of the Colors that appear in the Fill and Pen List under Active document, is there any way of achieving this? Can't see the item under the Purge command... I tried deleting everything from the file, run the Purge command twice but nothing gets rid of the Colors from the list. Quote Link to comment
axhake Posted March 27, 2020 Share Posted March 27, 2020 To purge unused colors, go to the "Attributes" panel and select the fill color In the top right is the "Color Palett Manager", select this Then on the LHS select "Colors in Active Document" the "Purge Unused" button at the bottom is now active, press and it will ask you to confirm you want to purge unused colors. Hope this helps 1 Quote Link to comment
axhake Posted March 27, 2020 Share Posted March 27, 2020 If you still have colors not deleting check the resource manager for the active document and see if you have any objects or symbols that have not been placed, some may have the colors in that will not purge Quote Link to comment
Gaspar Potocnik Posted March 30, 2020 Share Posted March 30, 2020 Thansks @axhake hadn't seen that. Since there is a Purge command, shouldn't the color purge be there aswell? Quote Link to comment
axhake Posted March 30, 2020 Share Posted March 30, 2020 you would have thought so 🙂 Quote Link to comment
tsw Posted April 2, 2020 Share Posted April 2, 2020 Expanding on this, I wish there was a way to delete used colors and replace them with another color in the document (much like the prompt you get when deleting a Class that is in use). For example, I often end up with two different named colors like "Gray-50" and "50% Gray" that are otherwise identical (often happens when importing other resources). It would be nice to consolidate the colors. 3 Quote Link to comment
