Gaspar Potocnik
140 -
Reputation
38 GreatPersonal Information
Occupation
Lighting Designer
Homepage
cueuno.com.ar
Location
Argentina
Recent Profile Visitors
Has anybody been able to get a bump on to a stl file? Just trying to get something like a voronoi displacement on on face of a model I have. Cheers
Status Bar!
Objects moving when importing MVR file
Gaspar Potocnik replied to mhersland's topic in Vision and Previsualization
I had this happen once (I think it was in January), with ladders actually, was in the middle of a tight deadline and didn't report it... -
Vision 2021 and metal
Gaspar Potocnik replied to Gaspar Potocnik's topic in Vision and Previsualization
I guess this is a NO go? -
Just watched the keynotes. It is mentioned that VW will use metal for the Mac version in 2021, what about Vision?would be nice....
- 1 reply
- 1
Hog PC & Vision whats it going to cost me?
Gaspar Potocnik replied to J. Miller's topic in Vision and Previsualization
I'm not 100% sure since I. haven't used a Hog in ages, but I believe you can only use sACN or ArtNET if you are using Vision on a Mac. A HogNET driver is available for windows I believe. -
Thanks @markdd!
So I finally get some time to fiddle around with this but I found myself not being able to get the "Lighting Device" record to show up when filtering. When I apply my criteria I can see it: But when I want to select the universe field to "color it up" I'm not seeing it, am I missing something? I've done the same workflow for truss and motors and that was no problem...
Why not changing the color of your symbols? If you want to keep de grey/black for renderings you only change your pen color so in wireframe it renders with color, if not you change both.
Thansks @axhake hadn't seen that. Since there is a Purge command, shouldn't the color purge be there aswell?
So I've been trying to get rid of the Colors that appear in the Fill and Pen List under Active document, is there any way of achieving this? Can't see the item under the Purge command... I tried deleting everything from the file, run the Purge command twice but nothing gets rid of the Colors from the list.
Problem solved, issue with the file and VW, after a reboot and using a new file this was fixed, old file still doesn't show images in worksheets... Thanks @Pat Stanford
Haven't tried this for a couple of years and note being able to make it work. Trying to make a basic list of symbols. My first column is =('Lighting Device'.'Inst Type') Second column =IMAGE Third column =COUNT I get absolutely nothing, no image, no count in the database header. Cell Format is set to Thumbnail-Top Plan View. I've tried: - different scales - Different view and render types in the cell format - Inserting Cireteria into de IMAGE column (Only difference here is I get a count in the database header and a TRUE or FALSE value but no image. - Generate a report - Create a new worksheet from scractch - New file and worksheet Any ideas? Bug?
Edit Multiple Subclasses
Gaspar Potocnik replied to Justinwest1231's question in Wishlist - Feature and Content Requests
I would add the ability to edit the father class hierarchy in the navigation pallet.
