so we need the ability to have a reversed Clipped Cube
need 2 types
1. is called "inspector" this is a virtual bubble that floats with your virtual head so when you fly through a complicated object it cuts a bubble about 1.5ft R or something in front of you AND stays with you as you fly through the model.
anything beyond the set bubble diameter is not cut anything inside the bubble is cut.
2. need a way to set up 3d objects that can be turned on so to cut away aspects of a model. right now i need to have 2 models, one complete and one cut away.
will need to have material fills which turn on when these are used. big red massing of all things cut do not help in inspection or story telling to 3rd parties.
digitalcarbon
need 2 types
8 answers to this question
