Jershaun Posted August 11, 2013 Share Posted August 11, 2013 Hi After being away from vw for almost a year now, I thought I'll test out vw a bit this past weekend. It look me +/-10 minutes to figure out I'll probably not be coming back to vw in it's current state. I downloaded the latest vw2013 & C4D14 and tested them both. Vw still can't handle anything that's non linear, its representation of curved solids is amazingly inaccurate, inconsistent and random. FAIL. Vw doesn't have realtime interactive rendering for hidden line rendering or the other modes. FAIL. There's no interactive elevations and sections. I can't model in these views! FAIL. No multi-core and 64 bit support. FAIL. Non destructive 3D fillets are not supported. FAIL. No 3D hatches! Now that's amazing in the modern age we live in. FAIL! Lack of customisability to roof and stair components. And the MOST IMPORTANT OF ALL: The link between C4D and vw DOES NOT work. Send to C4D, change materials, modify model in vw, send to C4D, all material settings are lost. Also, not all geometry is updated in C4D. This makes the vw/C4D combination unusable. Although Nemetschek owns both these software, it seems these 2 programs are fighting with each other. Autodesk seems to be a much more professional choice, the Revit/3dsMax relationship is far superior to vw/C4D one. MAJOR FAIL!! Because of the above, I've come to the conclusion, if I want to be serious about design, Nemetschek can't be an option. Sad to say especially C4D is such a great tool. Quote Link to comment
Kizza Posted August 11, 2013 Share Posted August 11, 2013 As you are an experienced VW user and a recent switcher to Revit, and in fairness to other board members, could you also list the VW features that you mostly miss in your daily workflow? Quote Link to comment
Kizza Posted August 11, 2013 Share Posted August 11, 2013 And two other things if you don't mind Jershaun: 1) Do you have issues with Revit crashing your system? 2) Do you have issues with inordinate file sizes and subsequent system slowdown on decent sized projects? Quote Link to comment
Bob Holtzmann Posted August 12, 2013 Share Posted August 12, 2013 There's no interactive elevations and sections. I can't model in these views! If I remember correctly, these are the only views Revit can edit objects in - the 3D views limit its editing ability. In the opposite sense, Vectorworks can edit anything at all in 3D views. I actually prefer to edit in 3D views anyway, just as I do in Sketchup. Quote Link to comment
Jershaun Posted August 12, 2013 Author Share Posted August 12, 2013 Hi @Kizza Actually don't miss anything from vw but if I had to choose it would be the smart cursor, linetypes and tile fills. Revit is extremely stable however the project I'm currently on is super large. It's so large that all disciplines have to split their models into various sectors and we then link those files into our revit models. Although all the models are split they still combine to create 1 model and this 1 model is being worked on simultaneously by +/-40-60 modellers in Adelaide, Melbourne & Argentina. Its extremely complicated but revit allows you to do this. The nature of this project is that models take extremely long to open up +/-30min. Most of you would now use this against Revit but I assure you, vw will not come close to handling this project especially it's not 64bit. Btw, I would be lying if I said revit doesn't crash but it's rare and it doesn't crash the system. @StructuralBIMGuy I wouldn't worry about that too much as I won't be using vw for a long time. Put it this way, when Nemetschek allows me to create windows, doors, etc. WITHOUT coding (ala families), then I'll upgrade (which means never? But I also said I'll "never" use Autodesk again). Quote Link to comment
Kizza Posted August 12, 2013 Share Posted August 12, 2013 Revit is extremely stable... Man, that gives me hope. There used to be an issue with file size even with relatively minor projects, but that was an issue back in 2009 I think. I'm sure Autodesk fixed it since. Quote Link to comment
Bob Holtzmann Posted August 12, 2013 Share Posted August 12, 2013 Put it this way, when Nemetschek allows me to create windows, doors, etc. WITHOUT coding (ala families), then I'll upgrade I don't do ANY coding when I make windows or doors - do you do something else besides clicking on the Window or Door Tool button, and clicking again on the plan? If you're referring to the Object Info Palette, I would much prefer to resize a door using sizes in fields, rather than manually re-drawing the frame, glass and muntins in a Revit family - it takes much more time to do that! There are more time-saving things I can go on about in favor of Vw, but I'm limited for time right now. Quote Link to comment
Christiaan Posted August 12, 2013 Share Posted August 12, 2013 I don't do ANY coding when I make windows or doors Right, and someone with Revit has the power to make far more window types than you do without any coding. Quote Link to comment
VincentCuclair Posted August 12, 2013 Share Posted August 12, 2013 (edited) would much prefer to resize a door using sizes in fields, rather than manually re-drawing the frame, glass and muntins in a Revit family - it takes much more time to do that! FYI: Once the window/door/(or anything else for that matter) is manually created (including as many parameters as you wish) changing window sizes is done in the same way in Revit as in VWs, all the parameters you set/created appear in the Revit 'OIP'!? Creating a family in Revit is basically the same as creating a hybrid symbol in VWs with the addition of side/section views etc.......the big difference is it's a parametric hybrid symbol. An example: in VWs we have control over the frame width and depth that's it, in Revit you could create a window with a very complicated frame with all the attributes editable in the OIP as long as you define the parameters in the Family when creating it. Theoretically you could even include glazing putty and make the sizes editable in the OIP. Edited August 12, 2013 by Vincent C Quote Link to comment
Christiaan Posted August 12, 2013 Share Posted August 12, 2013 the big difference is it's a parametric hybrid symbol. Indeed, which makes all the difference. The idea of relying on freeform modelling to manage window libraries should be long dead in water. Quote Link to comment
