jackmarling Posted May 1, 2013 Share Posted May 1, 2013 Hey all: after inserting door into wall I cannot get the header lines to not be visible. Only a problem in this particular drawing file. I have turned off and on all of classes....any ideas? Quote Link to comment
pgym Posted May 4, 2013 Share Posted May 4, 2013 Is the "Draw Wall Lines" option for the door checked in the OIP? Quote Link to comment
jackmarling Posted May 6, 2013 Author Share Posted May 6, 2013 no, "draw wall lines" is unchecked.... Quote Link to comment
taoist Posted May 7, 2013 Share Posted May 7, 2013 They are usually dotted lines that show in plan view that represent the header for the opening. Quote Link to comment
VincentCuclair Posted May 7, 2013 Share Posted May 7, 2013 Try turning off the Ceiling-Overhead class (or what ever class is connected to this in Standard Naming) Quote Link to comment
Christiaan Posted May 7, 2013 Share Posted May 7, 2013 They are usually dotted lines that show in plan view that represent the header for the opening. Is header and American term for lintel? Quote Link to comment
taoist Posted May 7, 2013 Share Posted May 7, 2013 Header in the states refers to the structural horizontal member at the top (head) of the opening. See image. Quote Link to comment
jackmarling Posted May 7, 2013 Author Share Posted May 7, 2013 Thanks, yeah, did that to no avail....funny that when I copy a door in from another file without this issue, I still have the issue with the imported door! This is Vectorworks 2013 by the way. Quote Link to comment
VincentCuclair Posted May 8, 2013 Share Posted May 8, 2013 OK either send the file to NVs for fixing or take a clean file and copy-paste. Quote Link to comment
SonnyLuong Posted May 8, 2013 Share Posted May 8, 2013 Well, can you make the header the sub-object mode of the door and assign it to a different class like rough-opening or something in that nature, and then have that particular class turned off? Quote Link to comment
Mitchell Brooks Posted May 8, 2013 Share Posted May 8, 2013 Are you sure you are not seeing either transom lines or threshold lines? Does the door have those included in its definition? Quote Link to comment
jackmarling Posted May 20, 2013 Author Share Posted May 20, 2013 Thanks! switched the door lintel class to a shut-off class.....perfect.. Quote Link to comment
