pgym
Content Count
71 -
Community Reputation
0 NeutralAbout pgym
Rank
Apprentice
You're right: it's their competence, the absence of which, given the annual demonstration of NV's programming team's inability to out even minimally usable releases (0 for 14 years and counting), and incapable of releasing service packs that don't introduce multiple new bugs for every bug that the SPs supposedly fixed, has been amply demonstrated.
At which point Nemetschek promptly abandons them and expects us to fork over another wad of cash for the "privilege" of beta-testing their new bug-infested crash monster. After the disaster that was VW 2013, we decided not to send any more dollars to Nemetschek until they released a STABLE 64-bit version, which, at the rate they're going, will probably be 12-15 years after the rest of the world has moved to 128-bit computing.
Sorry, but that excuse doesn't fly any more. OS X added 64-bit support in 2003 and has been fully 64-bit-compliant since 2007, Windows XP added 64-bit support in 2001, and Windows has been 64-bit since Vista (2006), so Nemetschek has had over 10 years to rewrite the base components: more than ample time for even a moderately competent programming team to do the job. (Hell, I'll bet a team of a dozen Baltic, Russian, Indian, or Chinese programmers could pump out a STABLE 64-bit version of 2014 in under a year). It's time to piss or get off the pot, Nemetschek: either make it a priority and get it done, or admit you never intended to do it in the first place.
10.9 Maverick Upgrade and Vectorworks 2011 not working anymore
pgym replied to alain's topic in General Discussion
Or they may be highly organized and managed professionals, who work for a company that is forward-looking and doesn't see a huge financial upside to devote the required resources needed to re-code and support versions of their software that are three years old. Given NVM's track record of bungling the initial release of EVERY version going back to at least 2006, their record of SP 1 breaking functions that did work in the initial release, their inability to leverage multi-core processing for anything other than some Renderworks modes, and their on-going unwillingness (or inability) to lay out even a suggested timeline to transition to 64-bit architecture, there is FAR more evidence for IanH's disorganized hackers scenario than for a highly organized, forward-looking professional scenario. -
Hmm ... Mountain Lion runs fine on my 17" Late '07 MB Pro (2.4 GHz Core 2 Duo), and Mavericks is running fine on our 15" Mid '07 MB Pro (2.2 GHz Core 2 Duo). IIRC, quad core iMacs weren't introduced until 2009. Maybe your iMac is an Early '07? -
You could try updating a few VPs at a time to determine whether any individual VP(s) is (are) causing VW to hang or crash, or if it's the sheer number of VPs causing a low memory/out-of-memory condition.
A number of earlier posts on VW2014 have been deleted from the thread, including one linking to a Knowledge Base article on 2014 system recommendations which revealed that 2014 will NOT be 64-bit. (Anyone want to guess how long before the censors remove this post?)
Layer Plane Persistence
pgym replied to willofmaine's question in Wishlist - Feature and Content Requests
You can set the options so that Vectorworks always uses screen plane if this is what you want. Yes, you can. The thing is, you shouldn't HAVE to. -
We never ever discuss unreleased products. I think this is pretty widely known. Oh really? What do you call the annual pre-release dog-and-pony show hyping all the half-baked new "features"? And how do you explain Biplab Sarkar's discussion of VW Cloud Services with Architosh, in March last year, well ahead of its release, particularly the closing paragraph:
I think it depends on how you use the tablet. I stream Keynotes (Apple's PowerPoint competitor) from my iPad to a pocket LCD projector connected to an AppleTV. That allows me to take notes or look things up on my laptop without having to switch away from the presentation. I also like to use Air Display to mirror my laptop screen to iPad when I meet with clients at their home or place of business and hand them iPad so we don't have to crowd around my laptop. It also allows them to watch me make changes to a model and see the results in something close-to-realtime. But I sure as hell wouldn't try that in Nomad. Although in Keynote or with Air Display, you can zoom in on any area of interest.
Obviously, you've never used Nomad outside the VW test lab, but keep on drinking the Koolade, Robert, keep on drinking the Koolade. You're right: it's 1/8th baked, if that.
Exported pdf files from VW are vector based, thus you can snap to them. Hmm .... I just exported several files and imported them into a new doc. Some snap, some don't, and some have VPs that snap and other VPs that don't! Wonder what the difference is? Oh well, you can always convert the PDFs to raster-based in Photoshop or another raster-based image editor.
Symbol opacity/transparency/fill/stacking issue
pgym replied to Jeff Porter's topic in General Discussion
Sounds like the symbol was created with no fill. To add a fill: 1) select an instance of the symbol; 2) double-click on the symbol or right-click it and select "edit" in the pop-up menu and select "3D geometry"; 3) select the 3d object; 4) change the fill to solid color (I prefer red or blue for testing purposes) At this point, try rendering the symbol (a simple QT render will be sufficient). If it renders fine, change it to white or whatever you want the final, untextured color to be. 5) apply any texture(s), if applicable; 6) exit the symbol. All instances of the symbol should now have fill and texture. -
Unless I'm misunderstanding what you mean by "flattened 2D version," I don't understand why you would ever deliver VW files to a client if your concern is to protect your IP. It seems to me that even a 2D VW file would provide enough detail to be used as a base to redraw a useable approximation the original 3D model. It probably wouldn't be worth the effort if the event was a one-off, but it might be worth it they regularly run events in the same venue(s). (Of course, they could import a PDF or image file and trace over it, but it would be significantly more work to get everything aligned since they would lose the snaps.) I'm not sure watermarking a layered file is an effective way of protecting IP. Removing passwords, digital signatures, and restrictions from PDFs is a pretty trivial exercise: heck, there are free websites that will return an unlocked copy to you in a matter of seconds. (In my other life, I'm a semi-pro musician, and there's nothing more irritating than buying password-protected or locked PDF sheet music that I have to go through 4-5 steps just to open and print out, only to discover a big honking watermark in the middle of the page that makes it difficult, if not impossible, to read.) You can then open the unlocked copy in Acrobat Pro or a layered image editor like Photoshop or Illustrator and strip out the watermark. The only way I could see watermarking being effective is if the file is a flattened image file (and even then, someone sufficiently motivated edit out the watermark in an image editor.)
