Mikael
Site Model odd behavior
I'm having a problem with Site Model...
I try to manipulate the Site Model with "Stake object from 3D locus" -command, but the result is odd.
See attached file.
I get that a lot. When you modify a 3D poly, by adding or moving points, you would think the Z elevation would stay the same, but it often comes in at 0 or the bottom allowed elevation.
Try looking in iso or from the side to determine if all the points are at the elevations you think they are.
There are no points, 3D locis or 3D polygons on wrong z-level to make such a result. This might be a bug.
I've purchased the Contour tool set, but haven't had the time to test it in a larger scale, but looks great.
Having a 3D polygon as a site modifier would be nice...
You CAN use any 3D Polygon as a Site Modifier. All you have to do is put it in the class Site-DTM-Modifier. Same applies to 3D Loci, Nurbs curves and Nurbs surfaces.
THANK YOU!
Why didn't I know this before? A huge time saver!
