APE Design Ctr Posted September 3, 2010 Share Posted September 3, 2010 I bought 2 brand new iMacs with the new i7 processors. Both have two identical problems: - I have a fairly large drawing (but not huge) with much 3D geometry. When I update viewports, I get either a crash, or an error that says 'viewport cannot be rendered because of lack of memory'. 'reduce the page dpi. However the dpi is only 200, plus I have 12 gigs of RAM. I have an old MacBook Pro with only 4 gigs of RAM, and it renders fine. Both iMacs have identical problems. I also have a 2 month old iMac with the i5 chip, and it works just fine. Anybody else having rendering issues with the i7? Thanks all. Quote Link to comment
Yoginathaswami Posted September 4, 2010 Share Posted September 4, 2010 I have no problem rendering with my iMac i7 processors. I wonder if it is your version of VW? Quote Link to comment
grant_PD Posted September 6, 2010 Share Posted September 6, 2010 the amount of ram is not going to make any difference, as VW can only get it's hand on so much of it anyway. Is there a setting in the system preference that is different between the macs on virtual memory, ram allocation for programs, page file, etc? Quote Link to comment
Yoginathaswami Posted September 6, 2010 Share Posted September 6, 2010 Is there a setting in the system preference that is different between the macs on virtual memory, ram allocation for programs, page file, etc? Aloha, Grant: I don't think you can allocate memory for applications in MacOS X. There are few things that can be done: 1. Run "permission repair" from Disk utility 2. Do the disk repair after safe boot. Quote Link to comment
APE Design Ctr Posted September 7, 2010 Author Share Posted September 7, 2010 Thanks all. I will continue to do some experimenting. Strange though - they are brand new uncluttered machines. Using VectorWorks 2010. Quote Link to comment
islandmon Posted September 7, 2010 Share Posted September 7, 2010 Possibly related to Quartz Imagery: http://techboard.nemetschek.net/ubbthreads.php?ubb=showflat&Number=137052 Quote Link to comment
domer1322 Posted September 9, 2010 Share Posted September 9, 2010 I have a 27" iMac i7 (2009 version but bought recently), 4G RAM and I am not experiencing any 3D rendering issues. I mostly use final RW (not OpenGL) Quote Link to comment
APE Design Ctr Posted September 15, 2010 Author Share Posted September 15, 2010 Domer1322, am I able to send a file to you to see if your VW2010 will crack? Thanks Eddie Quote Link to comment
domer1322 Posted September 15, 2010 Share Posted September 15, 2010 APE Design Ctr: I guess I'll try and help .. send your file to rocket1322@yahoo.com ..... but I think yahoo restricts file size to 5 Meg. If your file breaks my iMac, can I get some free playground equipment from you ? Quote Link to comment
