230 -
Calendar
Everything posted by Yoginathaswami
Creating Worksheet with Class name object count
Yoginathaswami replied to Yoginathaswami's topic in General Discussion
Thanks Pat! Once I checked the options SUMmerize and Sum Values, it worked as intended 🤙 -
Figured it out😃 -
Aloha, been very long time since I posted here! I am not very familiar with Worsheet in VW--rarely use it. I want to create worksheet that will give a list of Class in the file and total count of objects within the class. I have tile layout that has different sizes. I put each size in an individual class. It will be cool to be able to pull the count of tiles in each class along with the class name. I was playing around and was able to create the following Database with criteria "class is xyz" Function: "class" on the first column Function: "count" on the second column But it is not giving what I wanted... Any thoughts will be greatly appreciated! Thank you VW2021iMac
Property line object segments annotation
Yoginathaswami replied to Yoginathaswami's topic in Site Design
Aloha, rDesign: Thank you so much for pointing this out! 👍🏽 -
Congratulations to Jim and the NV Team!
Yoginathaswami replied to Kevin McAllister's topic in General Discussion
+1 -
Vectorworks 2016 is here, ask us anything!
Yoginathaswami replied to PVA - Admin's topic in General Discussion
Aloha, Jim: That will serve my need! Thanks! -
Aloha, Jim: Thank you so much for your tireless help! A quick question...is there pdf version of the "Vectorworks 2016 Help." It will be useful to me do refer to when I am offline. I did find the Getting started pdf files. Thank you so much! -
Opps! Too eager to help! :grin:
Aloha, Christiaan: Here us the link... http://www.vectorworks.net/downloads/ServicePack.php?major=2014&servicepack=1
Aloha, I just tried. It works just fine. Check if your Dimension class is turned on for the viewport.
Aloha, Ray: Thank you for mentioning all other names which I neglected in my post. I was truly sadden by the way the forum was heading due to frustrations and users feeling neglected. I love VW since I saw it in the form of Minicad 7. The responses from NVW staff--even if it is not the solution to the problem posted, made day and night difference with the general tone of the posts! Aloha
Aloha, Jim: You and couple others are very actively addressing many of the concerns that was brought by VW users. This is very much appreciated! Having at least one of you sharing your insights and possible solutions help a lot to us users. Your very frank explanations about memory issues and 64 bits are couple good examples. Keep up the good work! I hope you will continue this wonderful contribution. Aloha
Aloha, Justin: There is one setting that you can try in MacOS X pref. Click on the "general" you'll see a check box for "Close windows when...." This may not work when the application crashes but try it...
Aloha, Benson: Good point. That works for one or two...I can't imagine doing this when there is a need to do whole bunch of them. Wished there was a better solution... Thank you! -
Aloha, is there any way that I can move/reposition the annotated angle and distance text attached to the property line object? I have two segments that are too close to each other--causing the text to overlap. The only solution I found so far is to ungroup it; however, that converts the property line object to poly line and it loses at its bells and whistles. Thanks
Aloha, Bruce: What do you mean by "touch is turned off?"
Yes, thank you
Hi, Vijay: that is good way to isolate the crash. But Doug would have to live with many other apps that might not work properly during the test period. Isolating the issue as Ian points is better solution in the long run. Bill: You solution to the crashing issue definitely points to corrupted user permission. I would try to run the "safe boot disk repair first" as it is much less time time compared to creating new user account and setting up everything again. (My two cents worth for Doug.)
Hi, Doug: I am not sure if it is Java. However, it seems something from iMac's system or could be some other application installed triggering it. Specially when you have the same permission getting corrupted repeatedly. Do you recall installing any application before having this crash issue? It is one possible way to isolate the problem--as it is only happening on this iMac. Have tou tried booting the iMac on the "safe boot" mode and run the "fsck -fy" disk repair routine? If that doesn't solve it, you might want to contact Apple regarding the repeatedly corrupt permissions.
Aloha, Doug: Try running disk permissions repair from the Disk Utility application. A lot of times corrupted permissions will cause various applications to run really sluggish or crash.
Aloha, Thank you so much for all the input! Bryan is correct...I've uploaded a lot points from my total station and file size stays pretty small. I always keep my survey points as a stakeout points in VW. What is 3D loci and what is the advantage of using it compared to Stakeout point?
Aloha, please share your thoughts, ideas or suggestions regarding the best work flow for this. I am about to embark on a project of creating topographical map for our 70 acres monastery land. My first focus after collecting the survey data is to create topo lines showing the elevations. This will be used mainly for planning purposes. I learned to create topo lines using the DTM tool. (Thanks to Peter Cipes for teaching me). However, I am concern that this will create a giant file with all the 3D data. My current thinking is to convert the DTM to 2D lines. (Need to figure out how to do this.) Then if I ever need to actually work on project that requires cut and fill, I would just model that portion of the property with previously gathered survey data. Is this a right approach? Thank very much!
About that... We moved our web server and that messed up my image link. Thanks for the reminder...I'll take a few minutes to fix it. Aloha!
