Content Count
227 -
Community Reputation
0 NeutralAbout Yoginathaswami
Rank
Journeyman
Personal Information
Occupation
Monk/Minister
Homepage
www.gurudeva.org
Hobbies
Hindu Temple Architecture, General Architecture and Landscape
Location
Kauai's Hindu Monastery, Hawaii
Recent Profile Visitors
Property line object segments annotation
Yoginathaswami replied to Yoginathaswami's topic in Site Design
Aloha, rDesign: Thank you so much for pointing this out! 👍🏽 -
Yoginathaswami changed their profile photo
Congratulations to Jim and the NV Team!
Yoginathaswami replied to Kevin McAllister's topic in General Discussion
+1 -
Vectorworks 2016 is here, ask us anything!
Yoginathaswami replied to PVA - Jim's topic in General Discussion
Aloha, Jim: That will serve my need! Thanks! -
Aloha, Jim: Thank you so much for your tireless help! A quick question...is there pdf version of the "Vectorworks 2016 Help." It will be useful to me do refer to when I am offline. I did find the Getting started pdf files. Thank you so much! -
Opps! Too eager to help! :grin:
Aloha, Christiaan: Here us the link... http://www.vectorworks.net/downloads/ServicePack.php?major=2014&servicepack=1
Aloha, I just tried. It works just fine. Check if your Dimension class is turned on for the viewport.
Aloha, Ray: Thank you for mentioning all other names which I neglected in my post. I was truly sadden by the way the forum was heading due to frustrations and users feeling neglected. I love VW since I saw it in the form of Minicad 7. The responses from NVW staff--even if it is not the solution to the problem posted, made day and night difference with the general tone of the posts! Aloha
Aloha, Jim: You and couple others are very actively addressing many of the concerns that was brought by VW users. This is very much appreciated! Having at least one of you sharing your insights and possible solutions help a lot to us users. Your very frank explanations about memory issues and 64 bits are couple good examples. Keep up the good work! I hope you will continue this wonderful contribution. Aloha
Aloha, Justin: There is one setting that you can try in MacOS X pref. Click on the "general" you'll see a check box for "Close windows when...." This may not work when the application crashes but try it...
Aloha, Benson: Good point. That works for one or two...I can't imagine doing this when there is a need to do whole bunch of them. Wished there was a better solution... Thank you! -
Aloha, is there any way that I can move/reposition the annotated angle and distance text attached to the property line object? I have two segments that are too close to each other--causing the text to overlap. The only solution I found so far is to ungroup it; however, that converts the property line object to poly line and it loses at its bells and whistles. Thanks
Aloha, Bruce: What do you mean by "touch is turned off?"
Yes, thank you
