Peter Eichel Posted March 7, 2010 Share Posted March 7, 2010 Can a script be written that will draw two break lines and at the same time draw a solid filled closed polygon behind the break lines with its line color set at white and then group all three items. I currently use these when drawing sections as they speed things up considerably. Move them anywhere on a section and they hide whatever is behind them, no need to draw wall breaks anymore! VW designer 2009 Win XP Quote Link to comment
michaelk Posted March 7, 2010 Share Posted March 7, 2010 Would a blue symbol do what you want? It would insert as a group of the objects you want and be resizable as a group. Example attached... hth michaelk Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 7, 2010 Vectorworks, Inc Employee Share Posted March 7, 2010 Hi Peter, Yes. A script could be written to do this. I think the best solution might be to make it a path PIO that only shows a line with a break on visible line segments. This would allow the user to hide any segments you like by using the 2d reshape tool. It could also be saved (in common configurations) as red symbols. Quote Link to comment
Pat Stanford Posted March 7, 2010 Share Posted March 7, 2010 Yes it can be written fairly easily. The following script will place a break line object. Procedure Test; var H1:Handle; Begin H1:= CreateCustomObjectN('Break Line', 0,0,0,False); End; Run(Test); How you determine where the two break lines go and how big of a poly to draw is another issue. Quote Link to comment
Peter Eichel Posted March 8, 2010 Author Share Posted March 8, 2010 Michaelk, the invisible polygon needs to follow the shape of the break lines so that everything outside the twin break lines is visible. What do you mean by a blue symbol? Matt, I'm not sure what you mean by a path PIO, can you elaborate? Pat, I have never written a script so please bear with me. Is your script, starting with Procedure and ending with (Test); typed exactly as written word for word and will the polygon follow the break lines profile? In the meantime I'm going to look into learning more about scripts. Thanks all Quote Link to comment
Pat Stanford Posted March 8, 2010 Share Posted March 8, 2010 The script I posted draws exactly one break line at the position 0,0 with no rotation using the default settings for the break line object. It does not draw a polygon at all. I will have to think about how to convert the breakline to a polygon. Would just setting it to a really heavy line weight work? When you do it manually how do you do it? Quote Link to comment
Peter Eichel Posted March 8, 2010 Author Share Posted March 8, 2010 Pat, I create three entities, first I draw a break line using VW's break line tool, I then duplicate the break line and nudge the copy vertically from the original. Now I have twin break lines side by side that I use to create the third entity, a closed polygon. I snap to the points on both break lines creating a polygon that is inside or in between the break lines. The polygon's attributes are solid so it hides anything behind it as a section break does and it's line color is white so you don't see it's lines that cross from one break line to the other (all of this assumes one draws with a white background). When completed, you must move the breaklines to the front so that the polygon doesn't hide them. Group our new creation and drag where needed. No need to draw breaks in section walls for instance, just drag this where you want your break and you have it. Need to move a wall break to make room for annotations, just nudge this "portable section break wonder" to make room, it's fast and simple. Being able to create it with a script would be the icing on the cake so to speak. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 8, 2010 Vectorworks, Inc Employee Share Posted March 8, 2010 Peter, I use a similar idea as you but end up with just one polyline. The method I use is like this: Create one breakline. Option-drag a copy a desired distance away. Ungroup both breakline objects so that they are now polygons. While it may not be necessary, I then "Decompose" to turn them into lines. Draw a line from the end of one breakline to the closest end of the other. Select them all and "Compose" to turn them all into one polygon. Give it a solid fill and hide the one segment visually connecting them. While this method (and yours) does the trick, I like the idea of a PIO. BTW: A PIO is a Plug-in Object. The breakline object is a good example of a linear (defined by 2 points) plug-in object. A path PIO is defined by a polyline (3 or more points). Using a path PIO for this could allow any segment to have a break and could also allow any segments to be hidden. I could look into creating this PIO when I have some time. Quote Link to comment
Pat Stanford Posted March 8, 2010 Share Posted March 8, 2010 So how much bigger than the "break line" is the masking poly? The same height and with as the break portion? Or the size of the bounding box? Or something else? I have read you post about 4 times Matt and it is just not making sense to me. How does this create an object that will block the line it is placed on top of? It seems to me that what you need to do is draw a wide white line directly under the break line. What am I missing? Quote Link to comment
michaelk Posted March 8, 2010 Share Posted March 8, 2010 I think you're right, Pat. I think Peter & Matt are talking about something like the attached. Being a mere tinkerer and dabbler at these sorts of things, I did it with blue symbols. I'd love to see it done w/ a PIO. Not that I have any need for it myself, I'd just like to see how it's done. michaelk Quote Link to comment
Pat Stanford Posted March 8, 2010 Share Posted March 8, 2010 OK, now I get it. I was visualizing the break as being in-line with a line, not perpendicular. I think the script to do this should be pretty easy. I probably won't be able to get to it until late in the week, so someone will probably beat me to it. Thanks Michael. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 8, 2010 Vectorworks, Inc Employee Share Posted March 8, 2010 Michael's example looks to be what Peter's method is. If you take only the masking polygon, make the line color black, and hide the two segments that connect the two break lines, you'll have my method. I use this most often with wall section details where I may draw the full wall section from footing to roof, but make the walls much shorter to get the details closer together. Then I plop these break line polys over the wall to show a break and it masks out what's beneath. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 8, 2010 Vectorworks, Inc Employee Share Posted March 8, 2010 Whoops, I missed your post Pat and replied too soon... Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 9, 2010 Vectorworks, Inc Employee Share Posted March 9, 2010 I played around a bit with creating a PIO and it's working pretty well. Download it from this link, add it to your VW plug-ins folder, and add it to your workspace: http://panzercad.com/VW%20Freebies/plug-in_objects/break_poly_pio/ Only the straight break symbol option is available at this time. The PIO lets you create any polygon shape (it doesn't do curves) and shows breaks on any visible segments. It also has a Maximum segment length (without breaks) setting. The PIO will add multiple breaks along each segment as needed to keep the length between break less than this setting. You could create typical configurations with this object and save them as "Red Symbols" in the Resource Browser. Let me know what you think. :-) Quote Link to comment
Peter Eichel Posted March 9, 2010 Author Share Posted March 9, 2010 Matt, I downloaded your Break Poly PIO, unzipped it and placed it in VW's Plug In folder. When I try to add it to my Tools in the workspace menu it does not appear on the list. I re-checked VW's Plug In folder and your PIO is right there next to the Break Line PIO. Could it be a version issue, I use VW's 2009? Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 9, 2010 Vectorworks, Inc Employee Share Posted March 9, 2010 Hi Peter, Yes. It's a VW version issue. I rebuilt the PIO as a VW 2009 version (which should run on both VW 2009 and 2010). BTW: In the Workspace Editor, Look under the PanzerCAD Category for the PIO. http://panzercad.com/VW%20Freebies/plug-in_objects/break_poly_pio/ Quote Link to comment
Peter Eichel Posted March 10, 2010 Author Share Posted March 10, 2010 Thanks Matt, your PIO works great once I figured out how to hide that part of the polyline that "connected" the two break lines. I've never used the hide segment feature in VW's polylines so it was a pleasant surprise. Your creation is also superior to mine because I had to adjust the hidden polygon behind the break lines if I wanted to change the size of the break which was a pain! Your single entity idea eliminates the polygon. Nice work. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 10, 2010 Vectorworks, Inc Employee Share Posted March 10, 2010 You're welcome Peter. Yes, the hide segment feature comes in handy for this sort of task. I'm glad you like the PIO! It's certainly one I'll be using from now on. :-) Sooner or later I'll add the other break types to match the VW break line types... Quote Link to comment
Peter Eichel Posted March 13, 2010 Author Share Posted March 13, 2010 Hello again Matt, I have been using your break line PIO in my symbols where it behaves oddly. When you first create one it works as it should, if you change any of the parameters it loses it's break and becomes a box with the hidden line segment reappearing. Any ideas? Quote Link to comment
Peter Eichel Posted March 13, 2010 Author Share Posted March 13, 2010 Matt, I forgot to mention that the symbols I mentioned above were created in VW's 12 (mcd) and upgrade to VW's 2009 if that makes any difference. I was going to upgrade my symbol library, again created in VW's 12, with your PIO but we may have a version problem again. What do you think? Quote Link to comment
bc Posted March 13, 2010 Share Posted March 13, 2010 Thanks so much for this simple PIO. I long ago wished for something like this and have been working around it ever since. At first VW use, I expected the break line tool to actually break the objects it intersected like the split tool, HA! Not bloody likely...... EVERYONE BUY CAMERA MATCH! Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 13, 2010 Vectorworks, Inc Employee Share Posted March 13, 2010 Hi Peter, I just looked at the PIO closer in VW 2009 and there are some issues. One is a bug that is mine (in the PIO), the other seems to be a limitation in VW 2009. The one bug (that I don't think you experienced) is when editing the PIO within a symbol. The pio uses "page" units in it's parameters (ie: 1/8" means 1/8" in printed output no matter the layer's scale). When edited within a symbol, the PIO didn't know where to look for the appropriate scale. Now, it looks at the active layer's scale which is consistent to how other NNA objects work. I now fixed this problem. The other problem seems to be a bug (or limitation) with VW 2009's path PIO's. In VW 2009, In my testing, the 2D reshape tool (in toggle visibility mode) doesn't work when editing path objects. The workaround is to edit the PIO's path object (by double-clicking on the PIO) and use use the 2D reshape tool on the source poly. Get the updated (version 1.0.1) PIO here: http://panzercad.com/VW%20Freebies/plug-in_objects/break_poly_pio/ Let me know if this solves your problem. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 13, 2010 Vectorworks, Inc Employee Share Posted March 13, 2010 bc, You very welcome for the plug-in! I'm glad Peter brought it up to remind me to write it (after all these years). :-) PS: I'm glad you like CameraMatch! Quote Link to comment
Peter Eichel Posted March 14, 2010 Author Share Posted March 14, 2010 Matt, your de-bugging solved the problem, now this is one handy tool for doing section work! Thanks. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 14, 2010 Vectorworks, Inc Employee Share Posted March 14, 2010 No problem Peter. Glad to hear it's now working for you! Quote Link to comment
